sealbeach100d
Yes, no Dashcam viewer, but I though that was because (at least for me) I have an MCU1, not an MCU2.And also no Viewer.
I summons all the time, from driveway out to court with iPhone. Now 2020.12.5 cannot, message stuck on "warming up".
old |v2020.12|AP2,MCU1,PUP|
new |v2020.12.5|AP2,MCU1,PUP|
for some areas, try using the HD radio channels.....I use HD1 FM 101.1 (LA area) for normal and go to HD2 FM 101.1 for KNX radio 1070AM......a lot of radio FM stations have HD transmissions for AM stations"Cripple"! No, I think what you meant to say is if one chooses to upgrade from MCU1 to MCU2, a wonderful choice which adds all the current functionality of shipping cars, you will not have AM/FM radio functionality. This obviously due to hardware limitations in the retrofit. It is not "fixable" with a software update, it is not malicious. And it has nothing to do with USB music temporarily not working.
Can we please not refer to Tesla like a lame traditional car company.
HD channels have nothing to do with it. With the MCU1 to MCU2 upgrade, they replace the MCU. MCU2 has an input for a digital tuner (radio receiver). MCU1 uses an analog receiver. Problem is that replacing the receiver requires going deeper into the dashboard (behind the steering wheel). Tesla has apparently decided that the labor and parts cost isn't worth it, so when you upgrade you get a new MCU, but keep your old receiver (which can't connect to MCU2. As a result, you lose AM/FM/XM radio because their is no receiver connected to your MCU.for some areas, try using the HD radio channels.....I use HD1 FM 101.1 (LA area) for normal and go to HD2 FM 101.1 for KNX radio 1070AM......a lot of radio FM stations have HD transmissions for AM stations
oh...got it....I understand now....thanksHD channels have nothing to do with it. With the MCU1 to MCU2 upgrade, they replace the MCU. MCU2 has an input for a digital tuner (radio receiver). MCU1 uses an analog receiver. Problem is that replacing the receiver requires going deeper into the dashboard (behind the steering wheel). Tesla has apparently decided that the labor and parts cost isn't worth it, so when you upgrade you get a new MCU, but keep your old receiver (which can't connect to MCU2. As a result, you lose AM/FM/XM radio because their is no receiver connected to your MCU.
Is there any way to have a third party install of a compatible digital receiver? I really do like my am/fm radio. ThanksHD channels have nothing to do with it. With the MCU1 to MCU2 upgrade, they replace the MCU. MCU2 has an input for a digital tuner (radio receiver). MCU1 uses an analog receiver. Problem is that replacing the receiver requires going deeper into the dashboard (behind the steering wheel). Tesla has apparently decided that the labor and parts cost isn't worth it, so when you upgrade you get a new MCU, but keep your old receiver (which can't connect to MCU2. As a result, you lose AM/FM/XM radio because their is no receiver connected to your MCU.
New user and first post so go easy. Do we know what release fixs the usb issue as mined failed at version 2020.8.1. I just got update 2020.8.2 and it didnt fix it. My car is 2018 S P100D. Tried to speak to Tesla Australia 2 weeks ago and it was like i was speaking a foreign language. Reason why user here whing is because they dont tell us it a confirmed issue and it will
Be fixed.
i understand we are all beta testers but they just dont communicates. Love the car hate the service
end rant.
I have tried this a zillion times with different brands. They all work for 15 minutes and it says disk fulll afterwards. I check usb afterwards and it only 3gb full on a 64 gb usb. Also everything is now read only on the usb. I then change it to write and put it back in and works again for 15 minutes and does the same thing. Only happen after 2020.8.1. Since then i have 2020.8.1.1 and now im on 2020.8.2 tested as well.Let me ask you, have you tried:
1. eject your drive from the car
2. plug it into your PC or laptop
3. delete the current partition
4. create a new partition
5. format that new partition with fat32
6. create a folder named "TeslaCam"
7. properly eject said drive from your PC or laptop
8. plug drive into car
9. click and hold on the icon when it appears for a few seconds and the red dot should appear indicating that it is recording
It is imperative that you delete the partition and recreate it. Just formatting the old partition will fail to succeed in many instances.
Good luck!
Losing the AM/FM radio functionality is not 'due to hardware limitations in the retrofit'. Tesla chose to not include the digital tuner in the upgrade to reduce labor costs. It's not malicious but it is an example of doing the minimum effort they could get away with.
I keep hearing that it’s exceptionally difficult to reach the tuner. Just this week, I pulled out my left sunroof motor which is located next the steering column. As I tucked my head in there, right next to it is the analog tuner. Completely accessible. It only took me about twenty minutes to get the motor out having never done it before. I can’t imagine it would take much longer to access the tuner. I hear there are a couple of screws that are a little difficult to reach.HD channels have nothing to do with it. With the MCU1 to MCU2 upgrade, they replace the MCU. MCU2 has an input for a digital tuner (radio receiver). MCU1 uses an analog receiver. Problem is that replacing the receiver requires going deeper into the dashboard (behind the steering wheel). Tesla has apparently decided that the labor and parts cost isn't worth it, so when you upgrade you get a new MCU, but keep your old receiver (which can't connect to MCU2. As a result, you lose AM/FM/XM radio because their is no receiver connected to your MCU.
But I just can’t buy the story that the job is too difficult. Removing the MCU is waaaay more difficult. And once you’ve disassembled the dash to take out the McU, the tuner is right there.
30 jan 2020 delivery.......just installed 12.5......took 35:47......I was able to press the dash cam icon and the screen went to large front with side and back camera video in the corners......it was really nice......I had pressed the icon to down load all before I tried it but only the video within the last few minutes after the install was there.....not sure why.....but video was great......will go for a ride later and download and see what it shows then.....this really makes the dash cam set up complete.....no other issues seen so far
