I guess I haven't seen it yet. Can you point us to where this was proven?Is there actually speculation about this still? There's no way they unlocked additional capacity.
I too believe in Occam's razor. It would have been very easy for Tesla to limit the RWD batteries to 72kWh and then release the AWD batteries at 75kWh. Now if they made them both equal, the RWD cars gain 15mi.All available evidence and common sense. They de-rated the EPA numbers of the LR RWD at release, and have decided they can bring them back up now after observing fleet data. There's zero evidence to suggest there's ever been a software lock or other artificial limit on the battery.
The simplest answer is usually the correct one.
This appears to be what this reddit post claims, although it's from the energy page not the trip computer.If this number is virtually the same before and after the update, any added range showing on your car is almost certainly real, unless Tesla really gamed something and is now varying the watt hours per mile to hit rated range depending on state of charge (or some other trickery I haven't thought of).
My charging data pre- and post-update seem to support the exact numbers you are suggesting. I took an average of 15 or so charges before the update, and in those charges, about 7.2 kWh of energy was added for every 10% increase in SOC of the battery. This would equate to 72 kWh for 100% of the usable battery capacity.I too believe in Occam's razor. It would have been very easy for Tesla to limit the RWD batteries to 72kWh and then release the AWD batteries at 75kWh. Now if they made them both equal, the RWD cars gain 15mi.
Evidence that Tesla "uncorked" the Model 3 LR RWD's battery to increase the range with 2019.5.15 : teslamotors
It seems like concluding this is already determined via "all available evidence and common sense" is myopic. I have yet to see anything convincing for any of the arguments, hence my question.
I'm making this post so that I commit myself to running a test for the betterment of the community.
This Saturday I will do a 100% to < 10% run with my July 2018 Model 3 LR RWD that recently got 2019.5.15. I'll see how many kWh I get out of the battery in order to see if the update unlocked capacity or if it's just a recalibration of the number on the screen.
Tentative testing methodology:
Start with 100% charge
Drive to 50% and record the kWh consumed and miles traveled. Miles traveled is less relevant than how many kWh were consumed since it's still winter here.
Turn around and arrive back home somewhere under 10%.
Please comment with suggestions for this test. I want to perform a decent test and get good data.
Verygreen tore open the firmware and confirmed they just changed the wh per mile variable. They must have forgot to update in the energy app.
Tesla increases Model 3 range through software update. : RealTesla
Did you supply the wrong link? Because the link doesn't support your claim.
The link is referencing the comment by greentheonly on that post, not the Electrek article. That is a user known for digging deep into Tesla's firmware updates and is also the user that often posts detailed videos on what autopilot sees.
I understand that. My point is simply that he didn't actually say that he reverse engineered the firmware to the degree necessary to confirm his suspicions.
In otherwords, at this point it's still not hard evidence, just people posting opinions. I'm going to keep an open mind until I see evidence one way or the other.
Actually, the little evidence we have so far, does point to some amount of actual increase in range.
This is why technical folks like wk507 and verygreen get frustrated and quit this forum. Don’t project your lack of technical understanding onto others, verygreen has a good enough grasp on the Tesla software stack to make this conclusion.
This isn’t a PhD thesis he’s working on don’t expect a formal writeup. That variable change is pretty hard evidence. The only contrary ‘evidence’ in this thread is pretty much just magical thinking
I just the the full charge and I also got 322 miles.Sorry I don’t. I had just gotten the car and was so excited I did nothing scientifically. Which is totally against my nature. What I can recall is that charging from about 68% I got 322 miles range. I’ll report back on what I get today.
Mine was built June 19th, delivered July. After getting 5.15 I charged to 100%...no range difference- 309. This weekend will charge back up (takes a few days for me to run battery down, lol) to see if I get 325. I’m in Texas and drive in a manner where I typically actually get rated mileage range.Do you have data from before the 5.15 update to compare against? Or do you know what others have seen with respect to kWh consumed from 100% to almost 0%?
