4,700 miles on my Model 3 and my tires are on the wear bar
randy1077
Model X60->75 Vin 180XX. Model 3 Vin 074XX
May 20, 2011
90
82
Dallas, TX, United States
My Model 3 rear are wearing exceptionally fast. They are measuring 3/32 in the middle and 5/32 on the edge. The pressure has been very close to 45 psi for the entire time I have owned the car. The guy at the tire shop said they would not be covered under warranty because of the uneven wear. Is anyone else having this accelerated tire wear? I admit that I floor it at every light and use regen to its fullest extent, but 4,700 miles is ridiculous! These are supposed to be 55,000 mile tires. I have the 18" rims. These are the Michelin PRIMACY MXM4 - SIZE: 235/45R18
Dec 19, 2015
891
790
North Dallas, Texas
I second this. Mine are wearing faster than my Michelin P85D tires. I have even wear but I'm down to 7/32 front and 4/32 rear with 6,500 miles. I'm driving the 3 just like I did the S. My S tires lasted 20,000 miles.
Gouldness
Lurker
Nov 4, 2016
153
93
tampa
Honest q, how would you have to drive or setup the suspension or rotate to alleviate this so as to keep the tire wear warranty?
jsimon7777
219
99
Castro Valley
You can rotate your tires often. You can Zero out the toe and get zero to slight negative camber all around. Zero toe will make the car more lively but also more squirrely while on the freeway. Zero camber will make the car grip a bit less in corners. Both reduce tire wear. I've no idea what the standard settings are or what's adjustable on the M3. Camber probably needs aftermarket parts to adjust.
eigenv1
63
52
Oklahoma
Question to the tire specialists on this board: If the middle tread is wearing faster than the edges, could it be overinflation?
The upside is now you can purchase some better tires.
Daniel in SD
6,281
8,934
San Diego
You're right about toe but zero camber will make your tires wear faster unless you never turn :p
You should adjust your camber to keep the wear even between the inside and outside edges.
  • Disagree
Reactions: Mrcarcrazy
suwaneedad
921
1,113
Atlanta
7k miles. 44psi. Very even wear. I am careful when cornering; learned my lesson the hard way in the LEAF over the years.
Have yet to find a tire that can run to its warranty mileage when installed on an EV.
I expect to get 20k out of my delivered Model 3 tires; anything more is gravy.
Reactions: Olds442
usofrob
183
87
Michigan, United States
I have 48k miles on my stock all season tires on my S 90D. I'll want to replace them before this winter, but there's still enough tread for the summer rains. When I drive it by myself, I tend to drive at 7/10ths. But, I think the dual motors helps keep the wear even, and I am gentle on the tires unless fun is involved.
Reactions: pilotSteve
Daniel in SD
6,281
8,934
San Diego
Middle wear: over-inflation
Edge wear, same inner and outer edge: under-inflation
Outer edge wear: too much toe in
Inner edge wear: too much toe out
RWD should come with 265 in the rear, too much power and weight for those poor 235s.
Toe in and out have basically the same effect, accelerated wear. Camber determines whether the inner or outer edge wears.
  • Disagree
joetz
68
15
Florida
If I was experiencing wear like that I would get an alignment
Don't assume the car is properly aligned from the factory
Dana1
882
494
Houston
Why is an EV particularly bad on tires? The road and the driver are the same....
gaswalla
Model S,3,X.. CT with Austin delivery
Sep 23, 2012
3,253
3,523
San Diego
Only got 11k on first set of tires on the 3.. No spirited driving.
There is a service alert for early builds that apparently was causing early tire wear, but I'm not sure hope much it will help
Reactions: cybergates
