The brakes in your Tesla are conventional hydraulic brakes. If you push on the brake pedal, the brakes are activated. They're strong enough to stop the car even with the motor going full tilt. The car can apply additional braking force with the brake booster, but it cannot reduce the braking force generated by the pedal.
I think you were driving way too fast. Probably about 50? And you didn't start slowing down until very late.
Tesla vehicles monitor the brake usage and will scrub the brakes to clean the rotors if needed.Maybe because I use regen 99% of the time the actual brakes build up some film or are not properly worn in? (my car only has like 2,200 miles) In any case it was a little scary and I was lucky no one was in front of me.
1) Sorry, you were distracted and speeding. Why were you1. I was paying full attention to the road, so please do not assume distracted driving. Thanks!
2. About the speed I was driving at, I was driving at the same speed as other cars before the light. Don't know the exact number unless Tesla tell me from the logs.
- Driving faster than the cars around you?
- Braking later than the cars around you?
- Not pulling into the oh-sh** side-lane when it was obvious that you wouldn't stop in time?
That's more like being too careful and unexperienced to deal with this.
I’m going to blame the tires. Tesla’s fault for using crappy tires and your fault for not realizing how it handles in some wet situations.
I have the same config but got mine Sept 2018. I was driving one day after it had rained and had trouble with the tires losing traction on regen on an exit ramp. I had a few other times where the tires had wet traction issues slowing down and accelerating. What was your tire PSI set to? I kept mine at 45 and I’m sure that did not help things.
My solution was to buy PS4S summer and Nokian winter tires. The Nokian tires are not star performers on warmer wet roads but not as bad as the factory ones. PS4S tires are like the car is glued to the road dry or wet.
I still have my factory tires with 3,000 miles on them hanging on a rack in my garage. I guess I should try to sell them before they dry rot.
I just reviewed longer recordings before the accident, which showed I was actually driving slower than the other cars (including the Audi) and keeping a longer following distance.
3. I started to brake right after I see the red light & front car slowing down, with regen first and then immediately pushed brake pedal hard. I pushed as hard as I could and it still hit the front car.
Of course, another viable option is that if you had just been super-aggressively using the brakes (think track usage, not normal usage) you might have experienced brake fade.
Sorry my bad. In my native language, 'red light', 'green light', 'traffic light' basically means the same thing, which is the traffic light. I didn't mean I brake after I see the light turned red, but it's after I see the traffic light changing.You say you waited until after the light turned red to start braking. We can see in the video that the other cars started to brake when the light turned yellow.
You may have been going slower than those other cars in the minutes before the video starts. But at the time the light chaged red you are going way faster than them because they had already been braking for a while.
If you had started to break when everyone else did the accident would have most likely been avoided.
Welcome to share your opinions.
But I agree that I started braking later than other cars, for example the Audi. I'll learn from that.
Hey all, I've got into a small accident couple months ago and hope we can discuss about this.
Dash cam recording goes first:
(I only blurred the license plate for privacy concerns. Nothing else edited, for example speed, resolution, color, etc)
This rear end accident happened last year, and luckily nobody was hurt. My Tesla insurance covered this, and I told them the brake was not working as intended right after the accident. I also called Tesla roadside assistance & service center to report this malfunction, and they promised I would get an investigation result within 8 weeks. Not surprisingly that didn't happen. So I'm still wondering who is at fault in this accident, because it seems obvious to me that the brake wasn't right. Or maybe I could be wrong and need to be more careful in similar situations.
Here're some key conclusions:
1. The road was wet but not raining when it happened, actually it showered in the morning and stopped about half an hour ago. Temperature was around 50°F - 70°F (10°C - 20°C), speed limit is 35mph.
2. My Model 3 LR AWD was very new with 2000 miles on it. It has the original 18'' aero wheels & tires. Manual driving all the time, no autopilot involved.
4. The wheel was making deep clicking sound, indicating ABS triggered, but car just won't slow down and tire is making abrasive sound.
5. No collision warning, no auto braking or any other safety features triggered (I enabled all safety features).
6. Brake & regen still working after the accident. Have't tried braking hard though as I don't trust it any more.
Welcome to share your opinions. Thanks in advance!
A car to his left wanted to enter his laneI don't even know why he didnt slow down when he saw an orange light but decided to only start braking when the red light appeared.
