AlanSubie4Life
Efficiency Obsessed Member
Looks like the car ahead of you brakes at 9 seconds. Based on the “dive” of the nose of your car, looks like you did not brake until 12 seconds, immediately after the light turned red.
At that point, presumably the traction provided by the tires was insufficient to stop the vehicle. It appears perhaps you eased off the brake as well (perhaps in response to the sliding), but hard to tell.
This accident was definitely your fault, due to inattention. You need to allow sufficient following distance in all conditions.
I would have expected that if FCW was set sensitive, you would have heard it alarm prior to application of the brakes, in this case. But there is no guarantee of that.
