any icon originally on that row … shall we say the “vent” icon? press and hold that icon to open the customize controls page.which icon do I hold to open customize controls?
It's all in the finger swipe. Move icon to the last position with the middle finger, then use your index finger to swipe left to right across so your fingers are touching again, and then release. It took me a few tries to get it right.How did you add icons? On both my iPhone and Pixel 6, I can only replace an icon, not add an additional one.
I got six. Keep trying. You might need to adjust where you "drop" the icon a bit. Experimentation is the key!Awesome trick! But I can only get up to 5 icons — the swipe trick just replaces the icon that is on the second row.
Are you using iOS or Android?I got six. Keep trying. You might need to adjust where you "drop" the icon a bit. Experimentation is the key!
With your right thumb, pick up one of the available icons and drag it over the fourth icon ..., but do not release it.
While keeping your right thumb held down, use your thumb on your left hand to press on the 1st icon ..., and drag it to the second icon ... The icon you have brought up will move offscreen to the right into the invisible fifth spot.
Release both fingers simultaneously and VIOLA a fifth icon will magically appear.
In one of the later updates, it was restricted to 5 iconsDoes this still work? I could only get 5 icons. Can someone maybe do a youtube video showing how to get more than 5 icons?
