ItsNotAboutTheMoney
Correct, the key differentiator between GM's design and theToyota/Ford design is that the major gearis on the eldctric motor instead of the engine, which is better for an "EREV" design.I thought this was no longer true. The original marketing for the Volt was a series hybrid to differentiate them, but when it actua came to market, the power train was a blended hybrid. It can run in series mode some of the time, but they couldn't put a large enough battery and motor to cover the upper end of the performance chart, so it also has to couple the gasoline engine output directly to the wheels. Which makes it even more of a compromised and complicated design.
I believe that GM's Chevy-first approach was right. As a Cadillac it would be underwhelming and inaccessible. The ELR will just grab a few sales and ZEV credits and bide time until the Volt Gen 2 platform switch and other Voltec models which, not coincidentally, will be using US-made cells as LG Chem have basically accepted taking a short-term loss and almost certainly US-made motors that GM is building in Baltimore, initially for the Spark EV.
High performance Voltec would require a larger, less efficient engine and either a larger battery or the engine coming on under load. Either way it ups the cost and lowers the overall efficiency rating. The aim was mass market, trying to get a jump on Toyota. They over estimated sales like everybody else, but now they have a product I want to buy.
