tga
That doesn't help with 12V cycling.Just plug the car into a normal household outlet 110 with the mobile charger that comes with the car and forget about it.
A couple of times on this thread, members have asked a basic question: "How do hook up a battery tender to the 12V battery?" but the answers have not been detailed enough for newbies like me - not a newbie to Tesla, just to the forum. I've owned a 2014 MS 85 since new that now has only 35K miles on it. The 12V battery is the original. I'm going away for 3 months soon and after reading this thread, I want to leave the 12V battery on a tender as well as the car being plugged in to the HPWC just to cut down the recycles on the 12V battery. As I see it the only way to get at the 12V battery is by removing the front nose cone. When I do that, all I see is a +ve terminal (see pic) so I assume any -ve connection from the tender will just have to latch on to the car frame anywhere - correct? Is there some other easyView attachment 371505 way of removing the frunk lining to get a connection to the battery and just string the tender cable out of the frunk lid? I'd like to make it possible to use the tender in the future more frequently and having to pulling off the nose cone every time doesn't excite me. Thanks for help.View attachment 371506
Thanks - I assumed that as you can see from my original question. However, if you look closely at the photo in my original post, it can be seen that there is no negative post on my car - only the red positive one. The second part of my question was whether these posts could be accessed from inside the frunk without removing the nose cone.You will be fine with the charging the 12V battery with the frunk posts behind the nose cone... here is a photo of the ground terminal.
The terminals are also a great source of auxiliary power for operating other electronics with a 750W inverter.
View attachment 371589 View attachment 371590 View attachment 371591
Ron,Thanks for the reply!
When you just plug it in, what LED lights are illuminated on the NOCO G7200 charger? I had to close the Frunk latch by pushing down on the latch with a screwdriver so I can keep the Frunk open (the car thinks it is closed). This allows me to monitor the battery voltage and current draw with a DC current probe. Before I closed the latch with a screwdriver, my Model 3 would not go to sleep.
Thanks Again, Ron
RRolsbe, I have the same set up as you do and I just plug it in and let the NOCO do it's thing. I don't change it to Cold/AGM, just plug it in. I see about 120watts being pulled a few times a day. Over a 3 day period it will use about 1.2kw. I believe the DC to DC doesn't kick on until the battery gets to 12.6 or 5. If my car is sleeping is doesn't loose any over 3 days, this is the longest my car was sleeping at one time. Once it's awake it will over power the NOGO I believe then does engage the DC to DC.
I was worrisome about the 12 V battery on my Model 3, so I put a local voltmeter on the auxiliary 12 V plug.^This.
Here is what I think happens after doing some extensive voltage logging exercises.
First, the 12V battery does not "discharge" when the car is sitting.
The DC-DC converter raises the charge voltage to the float level and turns off.
Around 12.5 volts, the DC-DC converter charges the battery back to the float voltage.
The nominal voltage of a 12V battery resting is about 12.1 volts.
So all the car is doing is floating the battery.
My 24 Kwh backup battery in my solar system works in exactly the same way.
Keeping the battery at float is the best way to get the most life out of the battery.
It has to do with the chemistry that I won't go into.
I tried the external charger bit, and gave up after a short time.
It was a hassle and you still use electricity, whether it's from the auxiliary charger or the car charger.
By the way, the easiest way to access the 12V battery connection is to pull the 12V socket relay in the frunk
and put in a jumper across the output terminals.
This makes it live all the time. Very handy for charging a cell phone when the car is off.
Mike, nominal voltage of 12v is 12.6v at 12.1 that's about 52% SOC. I've attempted to monitor the CAN Bus and it looks like the DC-DC comes on about about 12.45 volts (80%) to top it back up. I don't have a data logger so it might be a little higher or lower, I'm sure someone on the forums knows the exact answer.^This.
The DC-DC converter raises the charge voltage to the float level and turns off. Around 12.5 volts, the DC-DC converter charges the battery back to the float voltage.
The nominal voltage of a 12V battery resting is about 12.1 volts. So all the car is doing is floating the battery. My 24 Kwh backup battery in my solar system works in exactly the same way. Keeping the battery at float is the best way to get the most life out of the battery. It has to do with the chemistry that I won't go into.
I tried the external charger bit, and gave up after a short time. It was a hassle and you still use electricity, whether it's from the auxiliary charger or the car charger.
By the way, the easiest way to access the 12V battery connection is to pull the 12V socket relay in the frunk and put in a jumper across the output terminals. This makes it live all the time. Very handy for charging a cell phone when the car is off.
Plenty of people do that, but you're being really unhelpful for the purpose of accomplishing what this thread is about.Just plug the car into a normal household outlet 110 with the mobile charger that comes with the car and forget about it.
HeyiCharge
What mode did you set your NOCO G7200 when you connected it to the battery. I connected my G7200 to my Model 3 battery and set it to the 12 Cold/AGM mode and the charger never topped off the battery. In this mode, the charger is supposed to top off the charge when the battery terminal voltage reaches 12.8V +/- 0.2V. I have a Kill-O-Watt meter and the G7200 AC line is being monitored by it. It only drew 20 watts over a 12 hour period so I know it did not top off the battery. The car however did top off the battery when the voltage across the terminals got below 12.7 volts probably closer to 12.6V. The power supply mode outputs 13.6V and appears to be supplying the Phantom current the car requires. After the Model 3's DC-to-DC converter completes the top off cycle the voltage at the battery terminals is 13..6V. Using the power supply mode, I am not sure the charger will back off if the cars DC-to-DC converter kicks in (ie.. the drivers door is opened or the phone app accesses the car); likewise, the G7200 charger does not remember the power supply mode setting and must be manually enable after losing AC outlet power. I think power supply mode would not overcharge the battery but simply maintain 13.6V and should also deliver the power required for the Phantom drain. Even if the G7200 topped off the battery at around 12.8V, it would still be cycling the 12V battery thus reducing it useful live. If the charger could just keep the battery topped off, supply needed Phantom current and not require the traction battery/DC-to-DC converter to top off the 12V battery, that would be ideal. I calculated the approx power usage using the power supply mode and it appears to be less than 9KW/month as apposed to over 30KW allowing the car to maintain the 12V battery. The traction battery should theoretically not loose any range even if parked for several weeks.
I cant say about a 2014 MS and an not sure if its similar to 2017MSA couple of times on this thread, members have asked a basic question: "How do hook up a battery tender to the 12V battery?" but the answers have not been detailed enough for newbies like me - not a newbie to Tesla, just to the forum.
Thanks for help.
for me, depending on the times when I check, it is either flashing red [charging] or steady green [ fully charged]Thanks for the reply!
Thanks Again, Ron
does Tesla have CANbus enabled to Charge the 12V battery directly from the 12-volt port?
see:
NOCO - .75A Battery Charger and Maintainer - G750
.75A won't even cover the "vampire drain". Any reason not to hook up a battery tender to the 12 volt battery ? says 4amps is your minimum target.
