sublimaze1
8Dec2012 / Leeroy Jenkins
No for NTFS formatted drives. IDK for others, some wouldn't even spin up.
Thanks. Looks like just a big SD card and call it a day.
I'm using a 64GB card from here I got for $40. Holds an awful lot of songs, even with many lossless. I suppose you could even use both USB ports, but then you'd not have all the songs together. (I've tried: You browse USB1 and USB2 separately.)
I decided to go micro. I purchased a 32GB micro SD and a USB reader that is the size of my thumbnail. It protrudes from the port about 5mm.
Discovered that .m4a aac files play, but .m4a Apple Lossless do not.
Also, flac woks up to 48khz / 24bit or 96khz / 16bit but not 96khz / 24bit.
Strangely a .mp4 video file plays, but you can only hear it. (No video output obviously.) Discovered that by accident when there was a file from work on the USB stick I was testing with.
Still haven't found a way to play discrete audio. :-(
And just a clarification on the spreadsheet: Multichannel .wav does play, but it only plays the first two channels. (Unlike multichannel flac which wouldn't play at all.)
The Lossless issue is easily solved. Once you put all your songs on the USB stick, just use XLD to convert them in place to FLAC. FLAC is of identical quality to Apple Lossless and no quality is lost in the transcoding since these are lossless formats. XLD is freeware--just Google it.
Storage. Okay, you are asking storage. Well, the port is a USB, so your final connector will have to be USB.
Now ...
You can get pretty much any solution (SD, SDHC, SDmini SDmicro, even MSproDuo) as long as your reader is USB
Now(2) ...
The class of the storage device will render your access time results to vary (e.g. a class10 SD16 in a quality USBreader is going to zip right through the songs, while a SDHCmicro32 class2 in a chinatek reader is going to be quite a bit (relatively) slower.
Petefish has already determined that a powered platter (e.g. a USB external hard drive) no workee.
Hence, as far as storage, it really is up to you. Look, style, color (colour), size ... your call.
Cheers
WJ
You gave me the answer I was looking for if I read you right. There is only a USB port, nothing else, correct?
slightly OT, but large music libraries on a USB that only play in alphabetic order are kind of useless for me, regardless of the audio formats supported! Until Tesla add playlists, folders, shuffle, etc. to the built-in player I plan on using bluetooth from my iPhone.
Yes I know how awful that audio connection is, but when driving I don't plan on having a pocketful of thumb drives, each with its own playlist!
