What does consistent regen braking feel have to do with it? It seems consistent to me across all SOC except >98%
Tesla gives the user the option to adjust the charge limit down to 50%. If there was no positive effect on the battery they would not add that feature. There is must be a positive effect to charge the battery only to 50% instead of 60% or 70% or higher.
With that in mind I really don't understand how people always bring up balancing and charging to a higher level would re-balance the pack. Tesla has explained why charging to a higher level after many shallow charges can 'bring back' miles. It's not balancing. Why do people keep ignoring this and rather go with the theory of balancing?
Unfortunately, this is less clear than it should be because the slider was really so that the EPA rated range wasn't averaged between the two, the way it was in the Leaf. The new Leafs now only allow 100% charging. My take is that the 50% level is mainly for storage. Mostly I charge at 80%.
Then why are there balancing circuits in the battery? There's a whole discussion on this with pictures showing them.
Can you please expand on this? I'm still a bit confused as to what's best for the battery and what to avoid... thanks.
... If you partially charge and discharge the battery the error adds up and the estimate gets less accurate. Obviously, Tesla wants to be on the safe side so it will estimate on the lower side to prevent the driver to be stranded. When the battery charged fully the data from the battery allows a better estimate and the algorithm is re-calibrated. This explains why people that have been charging only to a lower level and then switched back to 100% see their range estimate go back up.
I have a model S 85, one year old and 20k miles. Even though it fully charges to "260" miles vs. 265 when new, I have computed actual battery capacity and it looks like I am getting only about 72-74kwh which is a 15% degradation over one year. Fully charged, the battery is at "rated miles" and 100%. The trip meter does a pretty good job of showing total kwh used. So, multiply kwh used by rated miles used (not miles driven!) and divide by the fully charged miles to get fully charged capacity. I did this also using "percent charge" and got the same results.
Using the proper information, my battery has degraded somewhere between 2-3% over the last calendar year.Thanks for the info on available capacity.
No, that's not the case. The 85 kWh battery has 75.9 kWh usable capacity (before going into reds) to begin with when it is new. There is a graph in the middle of THIS page explaining usable battery capacity before rated range goes below zero.
