Malware
Just getting around to the install after buying the Blackvue a month ago. When I downloaded the BlackVue Windows Viewer 2.50 from BlackVue's site, I got an immediate malware warning from Windows Defender and the file was deleted.
Has anyone else seen this?
I just downloaded and installed it on Windows 10 with no issues.
Got it fixed. Completely took down the autopilot camera and could see that the light/rain sensor was unplugged. Plugged it back in and we're good to go now.Did you double check that your rear view mirror's plug is fully seated in? It may have been pulled out during the install. Also check the fuse that the mirror uses (unfortunately, I'm not sure what that fuse # is).
I just tried it again two days later with the same result--positive indication of a Trojan. Up-to-date Windows 10.
I emailed BlackVue support to see what they say . . .
This is their reply . . .
We have confirmed this with the blackvue Software security team. This is not a virus but a precautionary mesaure from the windows defender since blackvue PC viewer is not a well known program.
Also this problem is just with Windows 10 defender and sometimes with Norton antiviruses for some reason. You can also scan your computer with another antivirus to confirm it. People all over the world are using it without any hassle on other operating systems.
Correct. That is the fuse for the empty microphone box we are taping into.@valkeriefire just checking: is it the circled fuse you're referring to? I'm trying to find constant on fuses in the new facelift S as well (although ideally I'd like to find a constant on 10 amp or higher circuit).
What's it for?I just got delivery of a 70D with autopilot. There is a sensor/camera in the lower corner of the rear view mirror (driver's side) which doesn't exist in non-AP models. How far away from that camera does the BlackVue need to be so as not to interfere with it?
Thanks in advance.
I think it's for reading speed limit signs, eventually stop signs and traffic lights. I'm pretty sure it doesn't exist on non-AutoPilot models.What's it for?
