Why not ? The REX generates as much power as needed, it does not run on a constant speed. It is designed to give sufficient power without "using" the battery. Of course it will burn more fuel uphill.
<snip> It felt about 80 to 85% as powerful as it does in full electric mode and is easily capable of accelerating and passing even at these highway speeds.<snip>
There are reports out that the engine can do 28 kWh. And the Model S is a much heavier car, so maybe it would be comparable to 45 kWh in a Model S. Still pretty crappy. Someone will have to try it out on a mountain overpass and let everyone know...
After reading the reviews of ReX, the question that comes to my mind is why not 'Volt' ? It has real 4 doors and cheaper..
The Volt gets a green sticker which are limited in number and already ran out. The REx can get the same green sticker, but since it ran out, there needs to be legislation to add more green stickers first.Then why do all those Volts have them?
There are none. PlugShare is the best source.Is there a list os CCS fast chargers anywhere? In particular, anyone know of any in the Palm Springs area?
Are there any good leases available for the i3? We are also considering a bridge vehicle till the Gen III comes out as a 2nd vehicle to our Model S. It is either the Nissan Leaf (whee you can get lease deals for around $200 / mo) or possibly the i3.
I suggest you also consider the Mercedes B Class EV. It will likely have significantly more range, has a Tesla drivetrain, 4 real doors, more storage space, better rear quarter visibility, and doesn't look so odd on the outside. Same price. Going on sale in some US states in July according to Mercedes.
The white stickers that pure EVs get are unlimited in number.
The B-Class won't have CCS charging. Mercedes hinted at maybe adding it in a future version, but not for the current B-Class. As for the i3, I believe the launch versions have CCS included as standard, however, it'll be an option for the normal versions.I am unclear on whether the B Class will have CCS charging capability as standard or optional. In any case there are few CCS chargers in the US at this time.
