I'm getting deja vu, so I'm going to link my previous response to the same argument. Comparing charging quick charging speeds and the charging network is a useful comparison that EV buyers will make and can be a dealbreaker in comparing EVs.
Tesla Model 3 vs Chevy Bolt
I didn't think of this before, but your argument is similar to those that argue EVs are pointless unless then can go more than 300 miles on a charge. By your logic, we should give up comparing the range between EVs given they don't match an ICE anyways.
Yes, I'm being redundant because the EV refueling argument is based on misinformation on how automobiles are used for travel. You mainly charge your EV at home/work unless you're retired or too poor to afford plane tickets. There are people in the US who do not even own cars and they work and play just fine. So apparently the ability to go to North Dakota from New York each week by car is not as important as some folk think.
Elon Musk was well aware of the refueling issue. An EV that needs refueling for range extension is not competitive in that area with other automotive propulsion technologies. Musk went as far as designing the Tesla to accept a quick change battery pack, and putting in a global grid of super high output DCFCs,
The battery swap thing was not economically feasible. The SC grid still has gaps in it that require you to use slower refueling. Unpopular destinations aren't going to get DCFC for a very long time, and nobody is selling EV jerry cans yet.
Today, a BEV controls your schedule when used for long distance travel. When and where you eat and sleep are tied into charging infrastructure, and this simply is not true for gasoline or diesel. With ICE, you eat where YOU want and when YOU want, it's not your car's choice. It's the reason H2 will never catch on, and CNG/Propane are still limited to fleet use for the most part. There is certainly one thing gasoline is good at, and that is packing a lot of energy into very little mass, and that mass is liquid. It's the perfect freakin' energy source when it comes to remote refueling. Gasoline averages about 5 miles per pound. Li batteries? 5 miles per 15 lbs?
So if gasoline is so damn great, why is electricity better? Just to Save Teh Whales and Get Pot Legalized? No, EV tech is not tie-dyed t-shirts, sandals, and fancy bongs. It's a better engineering solution to automotive propulsion than internal combustion and I do not mean emissions control.
Electromotive propulsion allows for a car that NEVER stops for refueling during driving. Or you can refuel. You have a choice. You do not get a choice with ICE unless you have a butler or chauffeur. Our kids Volts are do not get refueled while in operation more than once a month. I think the 2013 gets refueled remotely every 2000 miles on the average, and the 2016 is probably higher. And these are VERY fast refuels since they are normally about 6 gallons.
Digital control of electromotive powertrains is simpler and more robust that trying to control an ICE engine and transmission. Things like stability control, traction control, 4 wheel steering, AWD, energy recovery, hill hold, cruise control, etc, are easy when you're electric.
Moving a heavy object is easier to do when you use electric motors. Cruise ships, trains, big earthmoving equipment, and even passenger cars are easier to propel when you use an electric motor. No idling, no clutch, no fluid torque converter, no gear changing, constant torque. But the instant throttle response at all times and speeds is really what make an EV a better way to drive than the other options.
But thinking that DCFC refueling Ozona, Texas is a critical must-have feature for a BEV is wrong. If that becomes the battle cry of the EV enthusiast, we are indeed doomed to extinction.
