Yes it is. Unless they eliminated the engine maintenance modes and ERDTT.
Some people don't even understand how their own car works.
I can attest to that. While I loved the Volt for what it was, I cant honestly tell people that we never used gas in it, even though my wife's commute was 20 miles daily, and we charged daily.
Once we got the MS in April 2013, the Volt never got driven beyond its battery range through the day we turned it in (lease termination) earlier this month. The range extender wasnt required after that point for distance reasons.
However, two scenarios initiated the ICE in that time. Once in the winter, it got cold enough here in PHX that the ICE came on to help the car warm up. It was only once, and it was the first time I'd ever experienced it. No big deal. It was on for about 5-7 min I believe.
Oh, you're one of those who believe everything you read on the Internet? Seems like there's a lot of that going around on this forum. Also, a lot of people here see what they want to see, regardless of what is actually written.From the Wikipedia article on the Voltec drivetrain used in the Volt and the ELR.
The general layout of the initial production platform is considered by some to be a plug-in series hybrid design since mechanical power initially drives the generator, which in turn charges the battery pack. Power is then drained from the batteries to run the electrical motors which move the vehicle. The internal combustion engine can run at a constant speed for both optimal efficiency and mechanical simplicity (i.e., there is no need for a multi-valve, multi- or variable-cam design). The Voltec, like the Prius, uses a planetary gearset to couple power from two sources to the wheels. Unlike the Prius, the Voltec only rarely drives the wheels with mechanical assist from the engine.[1][2][9] The Voltec could therefore be considered a power-split hybrid.
I would therefore counter your statement by saying only ignorant people make claims about how things work without doing any research.
Are you going to have your Model X retrofitted with Regen Paddles?
Sometimes you just want to coast without having to keep your foot on the accelerator to prevent the regen braking from kicking in. Regen paddles solve that problem with aplomb. It would be nice if the Model X offered that option, but it's probably patented by GM and only available if the technology is licensed. Still, one can hope. Luckily, it's going to be my wife's car, so I won't have to suffer much.I don't understand why Regen Paddles are better than the simple and effective one-pedal driving approach uses by Tesla where the regen is controlled by the"go" pedal. I love it. I want all cars to work that way.
If you had read my post more carefully, you would have noted that I take an annual trip (or two!) to Las Vegas from Los Angeles. After researching the real-world range of the 60kWh, I highly doubted it would make it from the Barstow supercharger to Las Vegas with an outside temp of 100 degrees while driving 75-85 mph, especially with all those extended steep grades.60 kWh would not cut it even though your commute is 36 miles per day except for the "rare long distance business trip" so I am guessing the 60 was too slow since range isn't the reason. That sort of shoots a hole in point number six. If a business trip is so rare why couldnt you rent a car for such trips?
Case in point: if you'd done your due diligence and research, you'd know the Voletc engine only assists the planetary gearset when the car is in Extended Range mode, and only then at high speeds or steep grades.
As for renting a car, why would anyone in his right mind spend all that money on a car knowing he'll have to rent a second one just to get where he needs to go? That's ludicrous.
Or in very cold temps. Or the gas is becoming stale.
For anyone who drives fewer than 35-40 mile per day (~75% of commuters), the gas is never used. Only ignorant people ... don't understand that.
Therefore, I am absolutely correct when I say I don't use gas during my normal daily commute (about 90% of my driving).
Sounds like the logic people use for having SUV's. They'd rather suffer the 15mpg all year than rent one for the annual family trip when they actually "need" it.
Which is exactly what you have done. Watch me prove it.Also, a lot of people here see what they want to see, regardless of what is actually written.
Which is entirely consistent withthe Voletc engine only assists the planetary gearset when the car is in Extended Range mode, and only then at high speeds or steep grades. The engine does not run at all (regardless of grade, speed, etc.) until the 16.5 kWh battery has been depleted below ~12.5 kWh (in the ELR... it's more like 11.5 kWh in the Volt).
I live in Maine. Last winter stuff was a bit messed but this winter the Volt will have a consistent set-up in our unheated garage. While I'm expecting the garage and plugging in to help moderate temperature, fact is that for 2 to 3 months of the year the average overnight low where I live is comfortably below the Very Cold ERDTT settings of 15F (I have a 2013). That means on my wife's morning commute the engine will run. She has a whopping 6 mile round trip commute. The fact that it runs the engine is annoying. They might think that since the engine's there they might as well use it, but it makes a nonsense of claims of it being an EREV and a mockery of all the Volt fanbois who criticize other PHEVs for having to run the engine for heat or performance. They may have covered the performance, but they failed to cover the climate problem and manufacturers of BEVs are able to do both. Even if most Americans don't deal with 15F temperatures, the default Volt cold setting is 35F and the default setting is also to allow ERDTT when pre-conditioning on the plug, which means unnecessary running of the engine for people in any locations that can get near or below freezing. The irony is that when marketing the Volt, GM's marketing first decided that the only thing about it worth marketing was that you go to the gas station much less often.
We go beyond range enough on longer trips that we aren't affected by the maintenance modes.
Posted by Blastphemy: "Sometimes you just want to coast without having to keep your foot on the accelerator to prevent the regen braking from kicking in. Regen paddles solve that problem with aplomb".
Yes, I can see that, but don't see a compelling reason for coasting. Is that a way to extend the EV range, and if so does it really make that much difference? I guess with such a limited range every bit helps.
I lug around a huge battery whose capacity I rarely use.Well most of the time still means you are lugging around gas and a gas engine that you rarely if ever use. If you almost never use it, why have it?
Half of my battery is expensive, heavy, and usually unnecessary.
What's the difference between using a big battery as a range extender and using a gasoline engine as a range extender?
The gasoline engine can be refueled fast, while the battery can be refueled at home. The gasoline engine requires regular maintenance.
but let's not pretend that someone is irrational for choosing a range extending option when that's precisely what the 85 kWh battery is to most of us.
You may rarely use the energy capacity of that huge battery, but I imagine you certainly use the power capacity -- that's what enables Tesla to put a 300-400hp motor on the car and get the blistering performance for which it's known and renowned.I lug around a huge battery whose capacity I rarely use.
- - - Updated - - -
Interesting. I'm fine with leaving my foot on the accelerator. I have precise control over the amount of electric acceleration/deceleration without thinking about it.
I'm not really sure why it's better to take your foot off of the accelerator than to just leave it on there. Leaving it on the pedal allows me to adapt more quickly to what's going on than pulling it off. and I imagine it's not like cruise control where you can take your foot off for a while; you're talking just taking it off for a few seconds, right? Otherwise, there's always "Neutral".
I concede that the first time you drive Model S, the regen is jarring. but after a couple drives, it starts to make perfect sense.
I don't really have much desire to exactly coast since the conversion between kinetic energy and battery energy is rather efficient at low torque. If 0 acceleration is good, would 0.01 m/s² be better or -0.03 m/s² be better? With the Tesla model you can get whatever the driving situation prefers without dumping the energy into friction brakes.
That's actually how the ELR works, but only in Extended Range mode (when ~12.5 kWh of the battery has been depleted). The only way the ELR can achieve Cadillac's advertised 0-60 in 7.8 seconds is in ER mode with the engine assisting. Otherwise, it's closer to 8.8 seconds 0-60 in EV-only mode. As I've asserted before, had Cadillac managed to improve the ELR's acceleration to even just 6.5 seconds 0-60, most of the people wouldn't be complaining about it appearing to be a dressed-up Volt (although I'm sure BEV proponents with tunnel vision would still be irrationally critical, even though ELR drivers are also doing our part to reduce pollution, reduce our reliance on terrorist oil, and mitigate climate change).A gasoline engine range extender does not get you that, unless you go the Fisker Karma route and require both engine and battery power to reach full electric motor power.
