MikeGracz
Wow, you guys have more DCFC in a block thane we have in our whole state! Cool! Thanks, it's comforting to know that I'll probably be able to use at least some of the stations between here and civilization...It was with a Tesla CCS adapter imported from Korea. I’m from the Tulsa area, if you look around on PlugShare in that area you can see entries for his testing.
Yeah, ccs is enabled.The two common problems I have heard from CCS users with any of the CCS cabinerts are the plug weight is so heavy and stiff that it pulls down and doesn't make good connection to the car's communications connections. I saw somebody used a telescoping stick to support it when plugged in.
The other problem is users will see the number next to the cable on EA cabinet and select that in the app. The correct number is the last digits on the number at the top of the cabinet.
My limited experience so far is that it took me about 5 minutes to begin charging doing everything right and the connection to the car was solid.
Preconditioning would only allow a higher peak charging at the beginning and higher charge rate for the first few minutes and shouldn't affect the activation of the DC charging.
On your car's side of the problem, I hope you did verify your Tesla has CCS adapter enabled. If you said that I missed it.
