BertL
OF NOTE: Despite the benefits I’m still seeing with less tracks on my USB SSD (no rescans or unexpected reboots in 10 days), in the past two days two other previously reported problems have reoccurred. IOW, memory mgmt isn’t the only problem MP has, and reducing tracks on your USB device does not workaound all the problems there are.
— I have a long-standing intermittent issue when I leave my MS with USB music playing, and my HPWC (dual chargers) does a recharge, MP sometimes switches to the first non-USB favorite which in my case is an FM station. Otherwise, MP has been doing a good job continuing to play the same track as I lock/unlock my MS — ever since I switched away from FLAC to 100% MP3 VBS encoding. IMO there is definitely a bug with what I’d call “unscheduled top-off charges” that may cause MP to switch away from USB music if you were using it. I don’t have this problem when Supercharging or IIRC when a real scheduled charge via my HPWC takes place. (I know of no workaround to this MP bug if you keep your MS plugged-in, don’t drive for a couple days while your battery drains, and then MS tops itself off at some future scheduled window — but once you get back into your MS, unless you also have the “zero tracks” problem (see below) simply selecting USB music gets things going again without too much trouble.)
— The intermittent bug where the CID has rebooted itself or MP USB has chosen to rescan while you’re away from your MS, and upon returning to your MS you’re left with MP seeing the USB device, but reports zero tracks until a rescan is manually forced (unplug/plug-in USB device or reboot CID), still exists.
