Then you haven't taken a look at your bill recently
The current EV rate in both plan A & B (separate meter) are no less than $0.12 from 11 p.m. to 7 a.m. Then add 5% tax. Rate plan B requires a separate meter ( ~$2k up front cost). Both bump up the rates for the peak and part-peak period, whennormal people actually live a life. There was also chatter about PG&E rate going up 11%.
https://www.pge.com/tariffs/tm2/pdf/ELEC_SCHEDS_EV.pdf
OP's consumption is very low. If he moves to these EV -plans, his regular usage will then become lot more expensive
because of his EV charging. This is exactly the stuff I argued about in another thread a while ago. If he just sticks to non-EV plan, he may get pushed into higher tiers, which will increase the per KWh rate for his charging at home.
There will be practically no saving; definitely negative saving compared to good hybrids. But I am surprised to learn that Tesla has already started exaggerating the gas savings for Model 3. They did it for years for Model S&X. Gas prices went down, but Tesla never adjusted those savings enough. Why does Tesla need to do this for Model 3? I thought they are trying to anti-sell it to reduce the queue for Model 3.
