@MMC- , wow that looks terrible! That appears to be a cosmetic issue on smaller screens, will fix right away, sorry about that.
@rush6410 , home-screen widgets automatically update every 30 minutes or so, though this can vary greatly between devices, and might not happen at all automatically if battery saver mode is on or if the device is asleep. All current widgets when updating will poll the vehicle's state.
Smart charging polls the vehicle's location every 15 minutes or so, although it won't necessarily poll the vehicle state unless you're at an enabled smart charging location where more vehicle state information is needed to continue processing.
Camper mode, cabin temperature protection, plug-in reminder all inherently poll the vehicle state.
Yes, turn off scheduled charging in the car. In 'Edit Smart Charging Location' turn on (check) 'Allow charge stopping'.Question is, does the app override whatever is set for scheduled charging on the car itself? Should that be turned off? May become obvious when I try to set it up but thought I'd ask.
Hey @SG57 ,
Last update (17) looks do have broken part of the charge screen. See attached.
Thanks,
Yes.Going to try using this for departure time charging. Getting sick of waking up to a warm cabin but a cold battery.
Yes.
Smart Charging requires either your scheduled charge to be disabled in the car so it can control exactly when to start charging without interference, or you must enable the "allow charge stopping" setting for your smart charging location to workaround any interference.
In detail, the "allow charge stopping" setting means you give permission to the service to send a "Stop Charge" command should it ever detect the car is charging when it shouldn't be based on your target completion time and your average charge rate for that location. So when the setting is enabled, you don't need to disable your scheduled charge in the car Smart Charging will immediately detect when it starts and stop it if necessary based on your desired completion time.
Understood.@hiroshiy , it makes sense that opening the app would fix it since the app queries the vehicle's state upon connecting which would cause the vehicle to wake up. Clearly the streaming API I'm using to get the vehicle's location is working in that it doesn't wake the vehicle up, but it's failing in that you're getting an unauthorized error while the vehicle sleeps.
If after disabling TeslaFi the problem still persists, there's nothing I can do. It's a limitation by Tesla that the streaming token being offered is stale/expired once the vehicle sleeps, unfortunately.
