@Kacey Green , I'm unable to reproduce the crash you've experienced when the app goes into the background. I suspect this may be device specific, by any chance is your device a Samsung Galaxy? Is the crash still happening for you reliably every time you minimize the app or switch apps? When you try to submit a crash report, even if the app crashes again (?), can you re-enter the email app it opens to send off the crash report? Sorry for the inconvenience, just need some more information here.
@hiroshiy , can you still reliably cause the smart charging service errors to occur? If you are running Android Marshmallow or newer do you have Battery Optimizations disabled? Do you have the "always connected" setting enabled in the vehicle itself? Do the service errors occur when your vehicle sleeps at an enabled smart charging location, or not, or doesn't matter?
If you could, enable Smart Charging Logging from the Settings screen at the bottom under Advanced section. This will save a log file on the root of your storage every time smart charging service runs with more details as to what happened. You should then try to reproduce the service error so its results are logged to the file, then share the contents of the log file with me either right here, thru PM, or send it to my
support email. Note,
all sensitive information from this log file is automatically redacted, so you're safe to share the log file contents.
I'm still trying to reproduce this error on my end, worst case I can have you join a closed beta version of the app that has additional tricks for troubleshooting and debugging this issue. Trust, we'll find it and fix it!
