SouthSeas
BTW, to clarify the principle I would like to note the following (I'm a masters student electrical engineering, so I understand more and more of physics principles, but also I make mistakes, so please correct me if I'm wrong). In normal language: higher temperatures make it easier for ions to move (higher mobility). Part of the degradation is the fact that the ions are 'pushed' through the resistance. That is also why ludricous mode heats the battery, since that makes it easier to extract electrons from the battery (so less voltage drop and less degradation because of use). On the other hands, the high temperature accelerates chemical degradation processes (dendrite forming, etc), but apparently the one effect outweighs the other.
I don't think you are going to find anyone here with enough battery knowledge to support or refute your statements.
What I can tell you is that lithium plating is a major cause of wear on the batteries. That is why these batteries can not be charged at low temperatures, the plating becomes extreme. It may well be that at higher temperatures lithium plating becomes virtually non-existent increasing the life of the battery, but I don't know that for sure. I would have thought this would have been known some time ago and all EVs would keep the battery not just above freezing, but hot during charging. 60°C is 140°F which is hot enough to burn you.
I will also say that heating the battery pack to 140°F each time it is charged is a large expense and waste of energy (waste in the sense of it doesn't propel the car). If they are using more than half the available charging power to heat the battery while slow charging that make the EV even less efficient than an ICE!
