Omg, I'm halfway thru my 1500 mile road trip. I gave up on using EA to save money on the road trip. It isn't worth it. I hit the same EA stations as I did the last time I made this road trip earlier in the summer. But this time it is much worse. First stop, 3 of the 4 stations were busted and the only working one was occupied so I went to a SC. The next EA stop I went to, someone cut the cables off the 350kw charger I used the last time I came, so I had to use a 150. I pulled 133, but then it throttled down to 35kw. I would've switched but an etron pulled into the other 350 next to me. I asked him if it worked, because the last time I used that charger on my last trip, I could only pull 35kw from it. He said it was working fine, but when I was sitting in my car I saw him switch stalls.
There was a SC around the corner, so I went there instead. It JUST WORKED when I plugged in... I skipped the next two EA chargers I normally went to, cus according to plugshare, 3 of the 4 chargers were busted. Earlier in the summer, only 1 of the 4 was busted.
So by the end of the day, I decided I'm done trying to save money with EA. It seems the ones in suburbia are pretty reliable, so I'll still use those when convenient while I'm at my destination. But the ones along I-5 are mostly busted all thru California now, from what I can tell.
