Another car break-in video. (So you can see how someone scopes out a car, and quickly moves in right after the driver steps away...)
Full agreement, of course. I can lose the window, I can't lose my cargo. And what I've done is to add my own "anchor points" to which I don't lock my cargo, I lock the rear seats. (And don't tell anybody, but I've also made my windows MUCH more difficult to break.) Yes, the thieves can still cost me money, but I now can guarantee that they'll be wasting plenty of time trying to do a repeat performance on my car.There should at least be anchor points in the back that can be used with a cable lock to secure items when this happens.
A broken window is one thing, Losing valuables is even worse. It’s not always an option to leave valuables at home or take them in.
Getting a bit tiresome to hear that *most* of these are in unlocked cars. And then in other videos we hear how 70% of them have valuables in view. None of this matches what *I* keep seeing, and what I experienced with my own car.Seems like there are a lot of videos from Florida... Not just a California situation.
Sounds like you have a sharp installer!Seems like a crime of opportunity and there is no way to deter that.
What about applying something that is a little flexible and strong yet clear and heals itself to the qtr class? Hmm. PPF.
My Local Installer actually thought of it so give credit to him.
Interesting to note that this report is from almost a year ago.
Far as I can tell, there's been no improvement.Interesting to note that this report is from almost a year ago.
Any improvement yet?
For anybody else who wishes to try this, I'm happy to offer some tips (assuming that like me, you don't apply PPF every day.)
I first used stiff paper to create a pattern of the window. (note that I cut holes through the paper, to stick it through the template to the glass). This was the step where I spent the most time. Testing and re-testing that template until I was happy with the fit. I left the edge toward the front of the car run long for maximum installation flexibility, and knowing (from testing) that cutting THAT edge after installation was the easiest to make perfect.
I then used a Sharpie to trace this onto my sheet of PPF (hint, ALWAYS warm the sheet up enough for it to lay flat. Don't make the mistake that I did, and try all of this in the cold garage with the sheet wavy from being rolled up in shipping. I did the first one that way, and the next one using warm sun to flatten the material. What a HUGE difference). Then, using my best scissors, I cut exactly on the line. Then I held the dry PPF (with backing on still, of course) to the window, and removed a few more slivers here and there until I was satisfied with the fit. With a spray bottle of slip mixture (a few drops of soap in water) and fix mixture (1/4 alcohol in water), I slapped it on there in a couple of minutes.
The part that made my job more difficult than it needed to be is the FIRST step I took, where I cut my new vinyl message and applied it to the glass in advance of the PPF. Getting the PPF to stick tight to those letters is going to take some days of drying, but so far it appears like it is going to work. I debated long and hard about putting my decal below or above the PPF film. Certainly the decal will last a lot longer behind the film, but it sure would have been easier to apply the film without the vinyl lumps under it!
Of the nearly 30,000 car break-ins in San Francisco last year, the police department made arrests in just 1.7 percent of cases, totalling 790 arrests, according to data provided by the police department and district attorney’s office. Of those taken into custody, most were never sentenced to jail time.
What do people think happens when these criminals are released with no jail time? They just take their luck smashing and grabbing some more.
Can you offer a bit more detail about your circumstance? Because in my case, the perp had a hell of a time just dealing with my interior tint on the glass. There was no "just peal the window inward/outward." He or she clearly struggled to penetrate the broken glass with intact tint, and when finally successful, the hole was no larger than a fist. With un-filmed glass, I often see almost all of the glass broken out of that window. Didn't happen with mine. And now that I've added PPF to the OTHER side of the glass, I just can't imagine this is going to be a case of "just break the window." Hell, I'm not even sure that a center punch is going to work the first or second time to crack the glass. And once cracked, that glass isn't going to go anywhere with the film sandwich I've made. Of course I'm only talking about that totally-framed quarter window. I agree that the door glass could just be folded down when busted... because of no frame.There is an apparent issue with this.
Based on my actual circumstances, the perps would just break the window and peel the window inward/outward.
I guess the more layers the better... but what does the vinyl bring to the table that the PPF doesn't? Additionally, I already know from experience that the PPF will stick best to the glass (or paint) and not so well to vinyl. So I'm afraid that stacking the films would actually diminish the effectiveness. The adhesive on this PPF is amazingly strong to the glass. I put a test piece on, and after only one day or drying (on a damp, winter day) it was REALLY tough to remove.Might be better to use Carbon Weave Vinyl to cover the entire qtr glass, and then PPF.
Need to fire up the ol' rumor mill again! What will this "Sentry Mode" entail? And why the heck would it be tied to AP? Wouldn't it be great if we could view all the camera feeds from the app, with alerts? Part of me is a bit afraid that maybe it'll allow the cameras to record on the thumbdrive like the dash cam... offering us not much more than a record of what happened. But hey, I'm all for *anything* that may help here.This should help: Elon Musk on Twitter
Elon MuskVerified account @elonmusk
Elon Musk Retweeted Andy Sutton
Tesla Sentry Mode coming soon for all cars with Enhanced Autopilot
