Fisker was facing the same issues early on in their delivery cycle.
Tesla's firmware issues are trivial in comparison to Fisker's. Tesla's stuff works well, with an occasional glitch. Fisker's UI was universally derided.
Either (a) Tesla is using a bandwidth limited plan and AT&T is saying that Tesla is hitting an artificial limit or (b) AT&T's general network needs an upgrade to support modern capacity requirements at least to 2005 levels.Another reason a tech told me for the slow roll outs was ATT was being overloaded with data. I'm not sure this rings true since the data could be rolled out in the wee hours. I hope we soon have the ability to have the car connect to our home wifi. My cell coverage is poor in my garage and it interrupts slacker when working on the car.
Since receiving 4.1 (1.19.31) my Miles Since Last Charge display does not reset to zero when I charge the car. Anyone else seen this behavior?
Or the original assertion was just a loose lipped excuse.
Just a few odities I've noticed with V4.1 - most trivial and probably mentioned here already... (I only had 4.0 for a day and a half so some of these might have already existed)
1. TPMS has mind of it's own. Sometimes tire pressures good, other times I get warning. It has been calibrated at service center. 35-36PSI on tires actual.
2. From time to time will get "charge door open" message with visual indication on left of instrument cluster - it fluctuates, ususally goes away.
3. Have had car shift to park a couple times while backing out of garage slowly - maybe it thinks the charging cable is connected and this is related to #2 above?
4. Have noticed the outside air temp dissappear from main display (dashes), but is on instrument cluster as others have noticed.
5. Wipers often swipe once when unlocking and opening driver door.
6. One time when I arrived at home and plugged in, it already showed 10 miles had been added on since charging started - that was a weird one.
Were you in Park? These buttons are grayed out when the vehicle is "in gear." If you were in Park, try rebooting the center screen by pushing down both scroll wheels on the steering wheel for about 15 secs.Also, I can no longer open the frunk, trunk or charge port door from the touch screeen (I think someone else saw this too). Hoping that 4.2 takes care of this collection of issues.
Heard something most concerning today. A friend left his S in his garage in Northern California plugged in over the Xmas week. Came home to a dead car, presumably a dead 12v. Tesla came for the car and told him today that they "think" the most recent update didn't fully install. How would one know that an update wasn't fully installed, other than a dead battery? Hopefully he'll get some clarification.
regarding service bulletins... How do they come? email? Is there a way to review prevous bulletins?
And I wonder if it continuously tried to install the update and killed the 12V battery?I had heard a similar statement ... the explanation was that the particular component firmware did not update.
Issue with 4.1 (.31 edition):
1. Set your Display setting to Night (instead of Auto)
2. Lock the car
3. Unlock the car
RESULT: Setting reverts to Auto
EXPECTED: Setting stays on Night
This happens with and without the "Keep Displays Powered" setting on.
Hadn't noticed that one since that's the default I like anyway.Just like the energy graph always reverting to "Instantaneous" instead of saving your setting.
