Nice work, Zankaman!
- - - Updated - - -
What's New in Release v4.5
New Features | Enhancements |
- Supercharger Locations
- Visited Chargers
- Charge Limit
- Maps
- Contacts Sorting
- Front Defrost Mode
- Battery Support
- Improved Battery Heating
NEW FEATURES
You can view a list of Supercharger locations in the Maps application by tapping the "Places" button in the upper-left corner of the window and selecting the "Superchargers" tab. Here you'll find the city and state in which the station is located as well as the approximate distance from your current location. This list will be updated automatically with new Superchargers as they become available.
- Select one of the Supercharger entries to view the map.
- Tap "Navigate" to generate a route to the selected location. We'll navigate you all the way to the Supercharger even in parking lots.
- The "flag" indicating the Supercharger location will display on the touchscreen until you have reached this destination.
You can also see the Superchargers that are near you on the map.
- Tap the lightning bolt icon in the upper-right corner of the Maps window.
- Select the "Superchargers" option.
- The map will zoom out to show you all the nearby Supercharger locations.
Visited Chargers
Locations where you've charged previously will also be listed in the Maps app.
- Tap the "Places" button in the upper-left corner of the Maps app and select the "Visited Chargers" tab.
- This list will show all the charging locations that you've ever charged at. These are sorted by proximity but are not limited to those closest in proximity.
- To view previous charging locations on your map, tap the lightning bolt icon in the upper-right corner of the Maps app and selected "Visited Chargers."
Charge Limit
Many customers have asked for the ability to adjust the Model S charge level based on individual anticipated driving needs. To provide this flexibility, charge level options, Standard and Max Range, have been replaced with a slider that allows you to specify the charge limit by percentage.
- To adjust the charge limit, tap the "Set Charge Limit" button and slide to the desired value.
- You can select form 30% to 100% charge.
- The new setting will apply for scheduled and immediate charging instructions.
ENHANCEMENTS
Maps
Street labels on maps viewed in 2x magnification are displayed in a larger, higher-resolution font.
Contacts Sorting
Phone contacts can now be sorted by first or last name.
This function is independent from preferences previously set on your phone.
New Front Defrost Mode
The Front Defrost control, located left of the Climate Control button, now offers 2 distinct settings: Normal and Max.
- One tap turns the icon blue and enables Normal Defrost, which maintains the current temperature and fan speed.
- Two taps turn the icon red . . . the standard behavior . . . .
Battery Support
When Model S is plugged in but not actively charging it will draw energy from the wall rather than using energy stored in the battery, e.g., when you've turned on climate control to cool/heat the cabin or when you're sitting in your car and using the touchscreen while it's parked.
Battery heating when charging on low wall power grid connections has been improved to ensure the battery does not discharge to heat itself.
"New Front Defrost Mode" still remains somewhat a mystery.
- - - Updated - - -
The
mystery text has been provided in this post:
Waiting for 4.5 firmware [now with release notes] - Page 17
