Vger
I've finally got the 4.5 update from 4.4
I also noticed that when i plug in with charge timing set the charge port indicator is green. Used to be blue until the charging actually started.
This is a feature. This means that the car is drawing power from the grid for whatever it needs in advance of the charging. Usually this is because the climate control is still on (e.g. if you left the driver door open while plugging in). If you close up and watch for a couple minutes, you will see the green change back to blue when the car stops drawing (big) power from the wall.
