Well not to confuse anymore, but mine just shipped with version 5.0 as 1.35.107 ....
And I thought the thread conversations about VINs were over the top!
Yes
- - - Updated - - -
Technically this does not mean they branched it and will merge the two back together. I believe that essentially this is the 'bug fix' version of 5.0. Certainly I could be wrong.
Not sure if the door handle auto-present behavior is normal either - I basically have to go pretty much right next to the car and wait a moment before the handles present. Just long enough to wonder if the handles will present. Also, if I approach from the rear of the car, it won't detect my presence and let me stop charging and unplug (I get a blue ring when I click the button, not a white one). I have to manually unlock the car before unplugging.
I am pretty sure the auto-present sensors are located in the triangular panels on either side of the dash. I disconnected one and the handles would not present until reconnected. Therefore, it makes sense that if you approach from the back that you get less of a response.
Makes sense to delay the roll out until all the bugs can be fixed. From what I have read it appears the GPS problem is related more to the gyros. Either a real problem with the hardware or a quick fixable problem with the firmware at the Service Centers.
If it's a hardware problem, then why does the GPS work fine in 4.5? Seems to me to be all software related.
If a cell phone with a 1440 mAh battery can poll the cell tower all day, the model S should not have issues polling. Unless of course they have it tied into other systems and require they are fully powered as well.
That's just it, they should be able to keep the car polling all day with negligible impact to battery, while putting the rest of the car to sleep.
1) The delay in start-up is getting really frustrating at time... Several times, it took well over 30 seconds after I was buckled-in.
2) My connection with the app has been extremely variable, sometimes taking as much as 15 minutes to connect. I was sitting at a restaurant today, right in front of my car, with an excellent signal on both my phone and car. Never connected after 20 minutes, trying resets, retries, etc.
The login server was down part of yesterday, hence the 20 minutes. The 30 seconds isn't a huge jump from the 15-20 seconds it has always taken, and is hardly unacceptable considering over a sometimes fast/sometimes slow connection it needs to verify security credentials, ping the car, wake it enough to provide data, etc. (and over a 3G connection on the way back, incidentally). Frankly it is a bit of a miracle of modern technology that it takes only 30 seconds. It takes longer for ESPN's mobile homepage to show up sometimes!That is slightly discouraging. Is this what everyone else with 5.0 is seeing? Initial estimates pegged start up time at 11 seconds, but 30 seconds is unacceptable IMHO. Also, 20 minutes for the mobile app? What's up with that? Seems crazy.
