An FYI to everyone who doesn't know: I learned that Tesla came out with a new TPMS sensor for the older Baolong sensors (<P50900). They're smaller and lighter (by 20%). I haven't had them installed in my new wheels, but I was kind of hoping I'd get the tire pressure app show up afterwards. I doubt it, as the limitation may be in the receiver and not the sensor themselves, but I'll report back, once they're installed (first week of November).
I also wanted to chime in on those thinking that the new interface is less taxing on the CPU/GPU/memory because there's less information. As a software engineer, I can assure you that the difference in speed would be virtually immeasurable (each data point requires a variable lookup when drawing, which takes << 20ns). So the excision of the temperature, time/date, etc was purely for aesthetics and has absolutely nothing to do with optimizing performance.
I really hope that Tesla can at least add the percentage of the battery as text, inside the battery image on the instrument cluster. The text may be too small, requiring them to make the battery image a little larger, but I think that would make up for the loss of 10% interval lines and reduced size/clarity of the image. To be clear, I know that we can switch to percentage, but I want to see both percentage and rated range. The vehicle information app, with the tire pressure, should also have more information, like battery temperature, perhaps with a visual indication of where that temperature fairs in terms of being cold, ideal, hot.
I will add that after using navigation, I think the way it shows up on the instrument cluster in v7 is gorgeous. That blend with the background and the way it fades into oblivion, instead of hard edges, is beautiful. Also, it seems unanimous that the new app icons on the center console are much nicer. The rest of the changes though leave a lot to be desired, and the flagrant waste of space on the instrument cluster is frustrating, to say the least.
