If this turns out to be widely distributed to the fleet I'm sure @Ingineer will post modules affected and we can all start looking for changes.Implied smiley? Are there any user-visible changes in this version?
What app are you using to know how long the upgrade took. I am not getting any software upgrade notifications from my Tesla app. I have deleted it and reloaded it. If it does not happen again when I get my next update, I will call Tesla support.
You covered the usual reason, which is that updates that affect summon usually reset continuous press so you need to (re-)disable that. I'd just call Tesla Service and be done with it.Summons isn't working on my MS 85. I press the central button on the fob (like I have done previously when it was working), lights flash, mirrors fold in, handles retract and then nothing. Recently updated to 2.24.30. Checked settings to make sure it was enabled (it was). Disables and then reenabled. Disabled continuous press and then reenabled it. Still not working. All the sensors appear to be clear.
Any thoughts?
Any thoughts?
Just checking, since you said that you disabled and then reeanbled continuous press. You are pressing and holding the button continuously, right? (I assume you are, but you never know sometimes).
Just saw that although I couldn't tell you when it happened because it never was a problem for me and my midnight silver car. What firmware version did you get and when did you get it?Yesterday before the latest update I noticed that the rear lights on the dash are now clear instead of red making it easy now to see when the brake lights go on. I have a red car and previously it was hard to see when they were activated. I don't know when the change was made as I just noticed it.
I hear you. I had the exact same embarrassment when trying to demo for my brother recently.Version 2.24 .86 yesterday afternoon. I was going to demonstrate Summons to a friend today and I could not make it work after the update. After many attempts and reading the manual the problem was I had to redo Hold the button down continuously to Off.
I don't understand. Who are you responding to and how do you know it only applies to MX?Keep in mind that the MS does not have falcon wing doors and consequently does not need that firmware upgrade.
Visible MX changes about 6/25:
1) Trunk does not hit garage door when it is opened in the garage.
2) Drivers door opens when car is unlocked with key fob.
Tesla HQ said I needed to disable the continuous setting. I did and summons from the fob worked just fine. Guess I thought the continuous setting was appropriate since I wanted summons to work while I held the center button on the fob continuously.Summons isn't working on my MS 85. I press the central button on the fob (like I have done previously when it was working), lights flash, mirrors fold in, handles retract and then nothing. Recently updated to 2.24.30. Checked settings to make sure it was enabled (it was). Disables and then reenabled. Disabled continuous press and then reenabled it. Still not working. All the sensors appear to be clear.
Any thoughts?
Got the same watch! Of course I spent $800 to have it cleaned and refreshed last year... Alas, it is not seeing much use since I got my Apple Watch...I am old school so I wear an actual wrist watch which is an Omega Speedmaster Chronograph (old 1974 Moon Watch). When I start the update I start the chronographs timer function by hitting the .... Button. When the update ends, I stop the timer function and read off the hour and minutes and seconds.... I am not aware of a software function that auto-magically keeps track of the upgrade duration.
