I liked it the old way too. I still needed two fob inputs to get the charger unlocked and get into the car though if I did not want to open the driver door right away. Now instead of holding tailgate button down 3secs to remove charger, the first dbl click takes care of that, still need to do it again to open the door.
Since the car "watches" your approach via RF of fob (for auto present) what if sensor activity can be integrated as well.
An good idea would be, when we approach the rear left quarterpanel (charge port) with the fob the ultrasonic sensors in the driver side fwd and left rear bumper would activate an unlock of the charge port without input from the fob.
So three conditions need to be met within a set period of time when car is locked and charging. 1) charge cable is engaged and locked 2) fob approaching 3) ultrasonic sensor near charge port detects you nearby
The charge port would then disengage the lock but remain charging until you push the button to stop it and remove the cable.
Sometimes, I want to unplug only without opening my door, still loading the kids etc. I would still like to double click to unlock and open driver door right away when I'm not.
