I believe the Collision Avoidance warning (at least what is sent to the MCU) is independent of the action FSDS takes.
Pretty sure anything that is sent to the MCU is post FSD computer and is just driver FYI. So it is a static one way post information link only.Seems so, but should it be linked?
I'd say the majority of my disengagements are correctness issues: the car gets into an incorrect lane (e.g. trying to go straight from a left-turn-only lane), or misses a turn entirely (most U-turns), or stops at a red light badly positioned in the lane, preventing drivers from getting past to make a right turn, and I get honked at. Potholes and road debris avoidance are also significant causes; these might cause damage to the car if not to the occupants. And agreed on needing to goose the speed constantly.This. In my daily driving I’ve reached the point where the majority of my interventions and disengagements are preference issues, not safety issues. With the significant exception of speed. 12.5 still can’t manage to pick the right speed so I’m continually goosing the accelerator to get it up to speed. If Tesla could fix that I would barely need to do anything.
What I also see a lot are cases where the system gives up or is heavily degraded due to sub-optimal visibility: rain, fog, nighttime with very low road lighting, sun glare, dirt on glass. These are cases where radar/lidar could supplement the cameras to allow the car to continue driving safely. "L4 but only in good weather" is a non-starter, because weather and conditions can unexpectedly change mid-drive. This is why I think the current 8-camera vision-only sensor suite is inadequate for L4/Robotaxi. Not because it can't do it in perfect conditions, but because perfect conditions are never guaranteed.
The other blocker for accepted-by-society L4 is whether the system is respectful enough of surrounding cars and drivers. Currently it does something every mile or two that is not immediately dangerous or illegal, but could seriously annoy nearby drivers. (And this doesn't even count the too-slow speed.) (And road rage is a danger.) This may be solvable by more training data or by a faster computer / deeper network, but it is emphatically not solved yet.
Following you on this. Are we saying Waymo works during a torrential downpour?
Think there will be cases where any automation won’t work, autos, humanoids, robots, etc
Gotta like good old humans, we are fully weatherproof all the way to a weather death threat.![]()
Shouldn't the collision detection warning system be taking its cues from the far more advanced driver assist system? If the driver assist is comfortable with dealing with the situation, why alert the driver? If it's not comfortable, then it should be sounding an alarm, regardless of the reason.Shouldn’t the collision avoidance detection communicate with FSD and cause it to slow down/stop?
I believe the driver assist code is through the FSD Computer too. Not sure how you determined it is "far more advanced" than FSDS code. Do you have a source to site or just speculation? If FSDS is active then it is in full control. You can't have 2 different programs fighting over control. If using FSDS you can turn ACW to Minimum to lessen the warnings.Shouldn't the collision detection warning system be taking its cues from the far more advanced driver assist system? If the driver assist is comfortable with dealing with the situation, why alert the driver? If it's not comfortable, then it should be sounding an alarm, regardless of the reason.
I'd certainly like to see a scale on the screen that indicates FSD's confidence level. Or a background shading system that moves through a spectrum of color.
Unfortunately those didn't exist when I did it lol, it was like 24 years ago or something close to that.
I can't wait to get off the 12.3 path. 12.3.5 and 12.3.6 have been net regressions for me. Slightly less frequent lane wobble than previous 12.3s but worse lane selection and somehow even more timid at intersections. Completely unusable at any remotely busy intersection without accelerator interventions. Also just forgets to put up turn signals sometimes.Just for kicks what is next?
- 12.3.7/24.3.x (where I would put my
on the lowest point)
- 12.3.7/24.9.x
- 12.3.7/24.15.x (Spring update before
???, not likely for us)
- 12.4.x/24.3.x
- 12.4.x/24.9.x
- 12.4.x/24.15.x (WILD a$$ dreaming thinking Tesla would do it all)
Lately just about everything I get annoyed about relates to it doing something "not fast enough". Obviously stop signs, but now I'm seeing this reluctance to make a lane change when I ask for it. If there are no cars in the lane I want to change into, it's immediate. But if there's a vehicle, even waaaaay back so an immediate lane change would be very safe, it demurs until the opportunity is basically lost. I have to either disengage to make the lane change or turn off the blinker and have people rolling their eyes at me (as I'd then be doing myself).The other blocker for accepted-by-society L4 is whether the system is respectful enough of surrounding cars and drivers. Currently it does something every mile or two that is not immediately dangerous or illegal, but could seriously annoy nearby drivers. (And this doesn't even count the too-slow speed.) (And road rage is a danger.) This may be solvable by more training data or by a faster computer / deeper network, but it is emphatically not solved yet.
In my experience if you are within about a mile of the next turn it will ignore your command to change lanes, and just cancel the signal.But if there's a vehicle, even waaaaay back so an immediate lane change would be very safe, it demurs until the opportunity is basically lost. I have to either disengage to make the lane change or turn off the blinker and have people rolling their eyes at me (as I'd then be doing myself).
I have to press and hold the turn signal button to force it to lane change, otherwise it turns off the signal and ignores my request. Not sure how you would do it in a vehicle with a stalk.Lately just about everything I get annoyed about relates to it doing something "not fast enough". Obviously stop signs, but now I'm seeing this reluctance to make a lane change when I ask for it. If there are no cars in the lane I want to change into, it's immediate. But if there's a vehicle, even waaaaay back so an immediate lane change would be very safe, it demurs until the opportunity is basically lost. I have to either disengage to make the lane change or turn off the blinker and have people rolling their eyes at me (as I'd then be doing myself).
Edge case, not disengaged
2023 MYP with USS running 12.3.6
Multi lane busy road, car ahead makes a bad slow left, while passing it in the same lane, the slowness of the turning vehicle and my approaching MYP, my collision avoidance warning sound goes off, the MYP goes slightly to the right to avoid and passes
Question
I did not engage, but consider it an edge case.
Hold down/up the stalk.Not sure how you would do it in a vehicle with a stalk.
1. The issue is not that it can't drive in a downpour today. The issue is that the HW3/4 sensor suite (eight fixed cameras pressed up against glass) may be fundamentally incapable of overcoming the resulting degree of visual distortion and occlusion. Clearly we can't expect a car to ever drive in an F5 tornado, but adding more and different/better sensors may expand the potential ODD from ~95% uptime (down 5% due to poor weather) to ~99.99%, which will be necessary for Robotaxi.
- I have no expectation of FSD working in a downpour. Just like a new driver, you learn to drive in good conditions first, then go from there.
- @Ben W - Just how do you expect the system to drive If the cameras are obscured? Do you not clear the snow off the windshield and windows before driving?
- I do still experience some lane selection issues but they are vastly improved from 11.4
- Humans aren’t fully weatherproof - actually the opposite. We need to be inside a weatherproofed car with the heat and wipers on! We do have a greater ability to accommodate suboptimal conditions, though.
A car with Waymo-level capabilities would either continue working or degrade gracefully (go into safe mode, pull over, and temporarily stop) during a torrential downpour. A Tesla tends to panic and fail abruptly. Clearly no car can drive in a Cat 5 hurricane. The difference is 99.99% uptime vs 95% uptime, and the manner in which the car handles the extreme conditions when encountered. For Robotaxi, the car will have to fail gracefully enough that it can safely pull itself over and stop. Red flashing "System Error: Take Control Immediately" is not an option.Following you on this. Are we saying Waymo works during a torrential downpour?
