sleepydoc
By that logic all numbers are made up, except for e, π, c, 6.02*10^23...Speed limits are also made up numbers...
I think 10 seconds is the UNECE regulation.
I think this refers to things like the car being on fire. Which should be detectable by someone in the car but not by the car itself.
Speed limits are numbers that have been decided upon and codified. "10 seconds" appears to have been made up by people here.
The SAE document specifically mentions suspension issues as an example of an issue that should be detectable by fallback person but again, there's a contradiction in that an remote fallback person would not be able to detect any of these.
FYI, the UNECE document states:
"The initiation of the transition demand shall be such that sufficient time is provided for a safe transition to manual driving"
and
"In case the driver is not responding to a transition demand by deactivating the system (either as described in paragraph 6.2.4. or 6.2.5.), a minimum risk manoeuvre shall be started, earliest 10 s after the start of the transition demand"
This was the only reference to 10 seconds that I could find. I haven't read the entire document but the UNECE guidelines appear to be much more prescriptive than the ASE guidance. That could lead to more uniformity but could also be problematic if it's overly prescriptive in ways that aren't appropriate for local driving customs and conditions. It will be interesting to see how it all proceeds; I can easily see the EU adoption the UNECE rules and the U.S. having its own (or even worse, every state having its own.)
Like I mentioned above, 'level 3' is broad enough that you could have a 'level 3.1' system and a 'level 3.5' system that is still level 3 but more reliable and capable. Regardless, especially in the beginning I would expect there to be signifiant numbers of circumstances in which L3 systems would need to time out and have the driver take over. The key is how to do this safely. It's very possible to have the system alert and then either pull over or simply slow down and stop with the hazards on if there is no response. The UNECE document specifically references this. If you can't handle these situations then a L3 system will never happen.Oh, not me. It took me 15 minutes to get out of bed this morning.
Joking aside, I'm highly skeptical we ever see wide rollouts of L3 systems with these short 10-15 second takeover times. Humans are bad drivers already under normal conditions, let alone acquiring situational awareness within a few seconds. Slightly more likely, IMO, is a system with a strong enough safety record that the manufacturer would be comfortable with no driverless operation on highway and the only L3 handbacks are triggered at off-ramps where there is no time pressure.
