Why are you posting this over and over?
There is not a single forum for battery / charging and I thought it was relevant information for S,3,x owners. If that offends you well, move along.
It is poor etiquette to cross post the same thing in multiple places. It’s really best to find the one spot that you think is best and post there, even if it fits in multiple categories.
It’s also poor etiquette to post a clickbait title and just link to a video with no explaination. This and the cross posting just comes across as someone desperate to get views and isn’t going to make you many friends here.
If you really want to benefit the community you can post it once and add a quick sentence or two explaination with the video... “You can charge faster by charging at 20 amps instead of 15... watch this video for more details”. That way people who are interested in the video can watch it and learn and those who are already know about it don’t have to waste their time clicking through.
If you don't want to watch a 7 minute video:
"Use a 5-20 outlet instead of 5-15."
I really don't get your high level of concern over 117V. Allowable ranges for the input from the utility to your house would be 120V + or - 5%, so as you point out, 114V would still be allowed coming into your house. And any wiring run beyond that in the house itself is going to have about 1 to 2V drop anyway by the time it gets to an outlet/appliance. 117V while loaded and drawing current is extremely close to nominal and is of no concern at all.I notice you are seeing 117v while charging at the end of the video. You might want to check your wiring size / breaker quality and to make sure something on your end isn't causing the voltage drop.
If it is outside your house you should notify your utility. It's not uncommon in older neighborhoods to have overloaded transformers. 114v is the minimum spec for 120v per ANSI C84.1 but anything that far below 120v catches my eye and if you do see less than 117v I'd be all over someone to get that addressed ASAP. I tend to see 119-123v at my house (partly because I replaced most of the inefficient lighting, appliances, and HVAC reducing my load on the meter and transformer).
That statement may be totally factually correct....but is also totally irrelevant, because 117V from a nominal 120V supply isn't in any way close to being considered "low". Your suggesting to call the power company over a 2.5% variance is ridiculous.Running low input voltage ages equipment and will cost you in replacement equipment (forced upgrades due to premature end of life) all while producing more waste heat and using ever so slightly more electricity (making your utility bill higher).
Oh yeah, that hadn't even occurred to me, but that's absolutely true. It's not usually something you think of, because 120V outlets don't usually have just one outlet on the circuit.In the video, he has a 20a circuit with only one outlet on it that he changes out to a 5-20. He could have changed the breaker and the outlet and had a 6-20 which would have nearly tripled his charging speed.
That's what @davewill is suggesting above. Have to buy/make a NEMA 6-20 to NEMA 14-50 adapter and set the amperage manually, though.If you really want more juice out of a 120v outlet, replace the single pole breaker with a 2-pole 15A breaker and switch the formerly neutral wire to a hot pole. You must verify that the outlet is the only outlet fed by the breaker or you must decommission those outlets accordingly. Also label your wires accordingly.
Oh yeah!Actually you can make a 6-20 to 5-20 adapter and then you wouldn't have to set anything manually.
