The point (which I thought was already thoroughly explained in the previous post) is that an EV using a J1772 DC charger is limited to max 400A charging current and therefore the battery pack voltage becomes the limiting factor for charging speed when you want to exceed ~160kW. So your earlier statement that “battery pack voltage [...] will have no effect on charging speed” is not correct. And I don’t understand how you can argue that “800V charging does not provide faster charge speeds than Tesla already has” when it plainly does. 350kW > 250kW. Regardless, comparisons to Tesla’s charging speed really isn’t germane when talking specifically about EVs with J1772 charge ports and how the battery pack voltage does or does not affect the max charge rate on those vehicles.
It's going to be like the corvette C8. Huge dealer markups if you want one. Have to wait two years on a waiting list. Reservations with a dealer network aren't really reservations. On the plus side I am actually excited to see GM is putting out some cool cars now. What comes after this thing? I want to see a midsize pickup ev and a camaro ev. What I don't want to see is 10 crossover SUVs that all look the same....
350kW for a 200+kWh pack is not faster than 250kW for an 80kWh pack, it's slower. 1.75 C rate vs 3.12 C rate
I don't understand the comparison. Assuming the same Wh/mi for the vehicle, the mph at which you add range will be faster at 350kW than 250kW. All that being said, no one talks about what effect faster and faster charging will have on the grid. When I read about Atlis' 1.5MW charger, I though that that's an insane amount of power that would need to be kept ready at all times. The demand charges will be off the charts.
Because it's a larger pack but it's still charging at a lower C rate. Yes the higher voltage is a way to overcome the limitations of the J1772 DC charging standard in this case which I did not take into account.
What makes you think the CT will have a >200kWh battery? Was this information provided anywhere? Also, I thought Tesla was beyond the lab stage with their new battery tech and had an actual production line going at Fremont?
I wouldn't be so sure. The E-Hummer doesn't even exist yet. Not even in prototype form. Yet they expect to release next year?
The largest Cybertruck battery will probably be around 200kWh too, maybe a little smaller. But I think the Cybertruck will be under 400Wh/mi. I would bet a v3 supercharger will put about as many miles per hour into the Cybertruck as a 350kW CCS puts into a Hummer. 570Wh/mi from the pack, which translates to 600Wh/mi from the wall (EPA rating) is awfully thirsty, even for a Hummer. I agree GM is sandbagging their claimed range, and I wouldn't be surprised if the final rating is in the high 300s, like 380mi or so. Here's a thought: one good thing about bad aerodynamics is you don't lose as much range when towing. Cars like the Model X and Model Y, with really good aero, are known to crater their range when towing. That's because an aerodynamic car doesn't push much air out of the way of that very un-aerodynamic boat behind it. If the new Hummer has the aerodynamics we expect of Hummers, it'll be pushing a whole lot of air out of the boat's way. A Cybertruck with the bed cover closed will get 30-40% more range than a Hummer with the same battery, but a Cybertruck towing a big boat will only get slightly more range.
Tesla hasn't said, but this article is estimating 250kWh: Detailed Modeling: Tesla Cybertruck 500-Mile Tri-Motor Battery & HP As for the cell, at Battery Day, just a few weeks ago, they showed and said that the new cell had been proving in the lab but are still working on how to scale it up. So they are building some, probably enough for the upcoming Plaid MS. But even then, I think the fact that they pushed the Plaid MS so far into the future was to give them time to develop the new cell production. Otherwise, why wait so long? The design is done, it's been lapping at various racetracks for a while now. I think they need that new cell. Well, we are all speculating in this thread. We'll just have to revisit this thread in a year. But GM has plenty of experience putting vehicles into production. And they are not new to electrification. They have a lot of experience with all of their PHEVs and EVs. As we have seen, they are just scaling up their existing EV and truck tech (4 wheel steering, suspension, etc.), so this shouldn't be that much of a lift for them. In contrast, Tesla is building a whole new factory, working with entirely new materials, using brand new cells, in their largest ever battery pack, in a new segment for them, I could go on and on. I am confident that Tesla will tackle and overcome the problems, but it will not be on time....
Well, you are the one making concrete assertions, not anybody else I can see: So good to see you are tempering your comments. You use the blanket term "electfication", but although there are some common elements, there's also some pretty significant differences between Hybrid electrics and full BEV's. And Chevy clearly didn't parlay their experience with the EV-1 well. What's more the experience with the Bolt design is more LG's than GM's. So while GM understands production of an EV with the Bolt, in 2015 at ~14 months away from production they already had 50 cars desgined, buiilt, and in the process of testing and validation. In this case a working e-Hummer does not exist. So if GM, and not LG, are truly designing this, then it is actually an incredibly heavy lift for them. I'd say that Tesla has more directly-relatable experience on several of those fronts, with working versions of each already built, than GM has with completing the Hummer design/build, which needs to be done before production, obviously.
I guess we were talking about different things when discussing "charging speed", which is admittedly an imprecise term. I usually interpret "charging speed" to mean "charging power" (in kW). But it can also mean the rate at which battery range is added (in mph or kph). Discussions of C-rates are rarely referenced when talking vehicle "charging speeds" since it's not as relevant to everyday driving/charging utility. For example, an i-MiEV with a 16 kWh battery and 62 mile range could in theory be retrofitted with a high C-rate battery and a DC charger to allow for a 100% charge in 20 minutes and an impressive 3C average charge rate. But even then it would only be charging at 48kW or 186mph, which is what really matters, and isn't impressive at all. In contrast, since the Hummer EV will have a HUGE battery, it's C-rate won't be as high as other fast-charging EVs, but C-rate doesn't matter as much as kW or mph to the driver. (And its kW might be much more impressive than its mph since its driving efficiency will likely be awful, but that's a whole 'nother discussion.)
Yes but C rates are also related to cell chemistry and construction characteristics, so a higher C rate for one chemistry may not have the same impact as the same C rate on another chemistry. I look at cell level C rates as being indicative of actual advances in cell technology. Just building a bigger pack and charging it at a lower C rate does not show any cell technology improvement.
As I mentioned in my post above this one I'm mostly interested in cell level improvements for the reasons outlined.
Some of the same engineers who worked on EV-1 worked on the Volt. Likewise, Volt->Bolt EV. Yes, GM was under a huge time constraint to get the Bolt EV out before the Model 3. The first Bolt EVs were actually delivered to customers at the Fremont CA Chevy dealer. Across the freeway and over about a mile from the Tesla mothership. I have no doubt GM can produce it. But the real issue is that it it seems to be a halo vehicle. Dealers will stick ADP stickers on them, etc. So they probably won't sell very many of them. Just a placeholder until they can get a Silverado-like truck into production.
Yes, GM has experience alright. A fair amount of bad quality experiences (some very serious like fires & brakes) also delays. That is why so many people fled GM, Ford for Toyota, Honda, Nissan. Exclusive: GM delays Chevy Cruze debut by a year The next version of the Cruze, which had originally been scheduled to debut in late 2014, will now begin production in December 2015 By Ben Klayman, Deepa Seetharaman July 17, 2013 Exclusive: GM delays Chevy Cruze debut by a year - sources GM Reportedly Abandoning Full-Size Hybrid Trucks and SUVs The next generation of full-size GM pickups and SUVs will be almost entirely free of hybrid models, according to GM Inside News. Scheduled to launch less than a year from now, the new lineup was originally slated to utilize an updated version of the current two-mode system. Now, it appears the next-generation Cadillac Escalade may be […] Andrew Wendler Sep 5, 2012 GM Reportedly Abandoning Full-Size Hybrid Trucks and SUVs 1974 Chevrolet Corvette With a completely new rear to match the impact bumper installed last year at the front, Zora Arkus-Duntov's GT becomes the nearest thing to a high-performance crushproof box. Those of you maintaining a vigil outside your neighborhood Chevrolet dealership may just as well go home. The long awaited coming of the mid-engine Corvette has been delayed once again for at least another year. ByJOHN KLEIN Aug 1, 1973 1974 Chevrolet Corvette Zora Arkus-Duntov - Wikipedia Chevrolet Corvette - Fourth generation (C4; 1984–1996) The fourth generation Corvette was the first complete redesign of the Corvette since 1963. Production was to begin for the 1983 model year but QUALITY ISSUES and part delays resulted in only 43 prototypes for the 1983 model year being produced that were never sold. All of the 1983 prototypes were destroyed or serialized to 1984 except one with a white exterior, medium blue interior, L83 350 ci, 205 bhp V8, and 4-speed automatic transmission. Regular fourth generation production began on January 3, 1983; the 1984 model year and delivery to customers began in March 1983. Chevrolet Corvette - Wikipedia Chevrolet Corvette - Fifth generation (C5; 1997–2004) The C5 was the most completely redesigned Corvette since the Corvette's inception in 1953. Production of the C5 Corvette actually began in 1996 but QUALITY/manufacturing ISSUES saw its release to the public in mass delayed until 1997 Chevrolet Corvette - Wikipedia Chevrolet Corvette - Seventh generation (C7; 2014–2019) Development for the seventh generation Corvette started in 2007. Originally set to be introduced for the 2011 model year, its introduction was delayed for three years. It was finally released for the 2014 model year. Chevrolet Corvette - Wikipedia GM Issues 'Stop Delivery' Order on 2015 Corvettes Auto Maker Wants to Fix Two Potential Problems Before the Sport Cars Leave Dealer Lots By John D. Stoll Sept. 11, 2014 GM Issues 'Stop Delivery' Order on 2015 Corvettes General Motors recalls 640,000 pickups because seat belts can cause fires November 21, 2019 General Motors recalls 640,000 pickups because seat belts can cause fires GM recalls more than 600,000 trucks, SUVs worldwide over braking system error By The Staff The Associated Press Posted October 31, 2019 GM recalls more than 600,000 trucks, SUVs worldwide over braking system error On January 10, 2014, a recall was issued for 370,000 Silverado and Sierra pickups due to a fire risk. Chevrolet Silverado - Wikipedia GM recalls 1.4 million cars for fire risk after previous fix failed In all of the fires, oil leaked onto a hot manifold in the engine. by Chris Isidore @CNNMoney October 27, 2015 GM recalls 1.4 million cars for fire risk after previous fix failed GM delays Cadillac CTS Coupe launch until mid-2010 By Nelson Ireson January 26, 2009 GM delays CTS Coupe launch until mid-2010 GM F platform - Chevrolet Camaro, Pontiac Firebird, First-gen First Generation, 1967–1969 Due to delays with the design of the second-generation car, the 1969 models were produced longer than usual. GM F platform - Wikipedia
Actually, the EV-1 was developed in California not in Michigan. GM outsourced their EV program to Aerovironment in SoCal rather than develop it in-house. Many of the Sunraycer/Impact/EV-1 engineers went on to form AC Propulsion, which created the Tzero electric sports car, which in turn inspired the Tesla Roadster. Tesla's cars, not the LG Bolt, are the direct linear descendent of the GM EV-1!
