AmpedRealtor
I'm certain the Model S uses a reversible heat pump for both AC and heat, with a resistance heater as an auxiliary to the heat pump when it is below freezing outside. So it has heat exchangers for both the interior air and the exterior air, just like a residential heat pump system.
Having just bought/installed a couple of dehumidifiers, I realized that they are nothing but heat pumps for which the heat exchanger is inside the room being conditioned, basically a refrigerator that just cools air momentarily, long enough to condense out water, then rewarms the cooled air with the same heat it pumped out of it, plus the motor heat, and sends it back to the room. Operating either a refrigerator or a dehumidifier produces a net energy input to the room because there is no other place to which to pump the heat. In AC/heat mode, the heat gets pumped from inside/outside the car to outside/inside the car. So a dehumidification mode would just require that the exterior heat exchanger be switched to interior air flow.
If that's true, you should hear the compressor running when the heat is on. I don't believe that is the case.
