My Volt is even easier. You have the option for all seven days of the week to say what time you want the charge completed. It knows when to start to finish on time.
My first EV was a Nissan Leaf and it had the ability to choose your charging end time with v1.0 of their software, so DUH TESLA. Until Tesla adds this feature here is the "easy way" with only subtraction needed.
1. Plug in and start charging your car at the amperage you want to use with NO A/C or heat on (will affect time displayed)
2. After you start charging, the car will show you "Hours and Minutes Remaining"
3. Subtract the time remaining from your end time and set your timer to that time.
disagree. I like their approach on this one.It sounds like any one of us might be better qualified than whoever it is at Tesla making these decisions.
If I could design it it would work this way: if scheduled charging is enabled the user must enter a desired charging complete time (ideally by day of week). The user could also (optionally) configure a "not before" time.
So if I say I want it fully charged at 7AM and it needs 2 hours of charging then it would start at 5AM. But if it needs 10 hours of charging and I said not to start charging earlier than 11PM then it would start at 11PM and not be fully charged at 7AM. Now at that point it is debatable if it should stop charging or continue (or if that should also be configurable).
The location charging time is great but they need to add more than just one start time. On weekends my TOU rates don't apply so I can charge at anytime, it would be very nice to have a separate timer for the weekend plus a "finish charging by" time for the northern folks.As a ToU user, I would love this feature. Get the battery as warm as possible before my rates go up. I'm just glad Tesla has at least made some improvements. Those old enough to remember pre-4.5 versions? You plugged the car in and it started charging. No scheduling features at all! Many people wired timers into their 14-50 outlet to get it to start at certain times. Thankfully I wasn't using a ToU rate plan back then. You also could only pick between 90% or 100% charge.
Also, not given Tesla enough credit on is the location awareness for the scheduler. Not something you think about until you use another car without it. Whenever I use a public charger in my Fiat 500e, I have to remember to go into it's settings and disable the schedule before plugging in. And if I forget and close the door, the option goes away and you have to restart the car to get to the option again.
The techies aside, simple is probably better. The more complicated the options the more the masses will be confused (even if they don't need the options).
Ironic, I've got an eGolf where you can ONLY specify departure time (not charge start time), and a Model S where you can ONLY specify charge start time (not departure time). Given the two models, I'd say that I far prefer the Tesla one. I start charging off peak at midnight, and complete off peak early AM sometime, regardless of whether I'm adding 10% or 90%. If I decide to depart earlier than normal, no problem. Put another way, if I have an early appointment and I forgot to change my departure time, no problem. In terms of making the charging completely transparent, I like the Tesla model. All I sacrifice is a couple of miles per day of vampire loss. At off peak costs, maybe 25 cents? I hope Tesla adds departure time to satisfy those of you who want it - but it is certainly way down on my priority list, and I pray that they don't eliminate the option to use start time.
So what most people here are saying is that every little thing another company comes up with, Tesla should have it to. Ok, then pop on over to those companies respective sites or call the companies directly and tell them their cars should have everything the MS has.
Is it really difficult to do some basic math. you need 90 miles added to get to 90% by 7 am? Start the charging at 4 am. Problem solved.
The same argument against adding departure time to the app is the same argument against adding Autopilot to the car. Autopilot is as far from KISS as humanly possible, in my opinion. KISS is not a good principle to follow when you have the power of software that can make life so much simpler. It's a good feature to have and Tesla should implement it. It's a basic, simple algorithm that a high school programmer could put together.
