2005 Acura RL had active noise canceling (ANC). Worked quite well to remove low frequency engine noise. Did nothing (and didn't try) to eliminate wind noise and tire noise. The ANC used the audio system as a source of the out-of-phase sound signals. It's now available throughout the Acura line.
I believe ANC has moved to Honda's as well.
Active Noise Control (ANC) technology (a.k.a., noise-cancellation technology) has severe limitations, and it is not the panacea to solving cabin noise. Here are the criteria for ANC to work:
1. There must be a 2-dimensional plane wave propagating in the space. This happens in HVAC ducts, pipes, vent stacks, etc., and most everything else has 3-D spreading of the sound waves.
2. Due to the short wave lengths in sound energy above 1,000 Hz, (wave length less than 1 foot) ANC does not work for noises with frequency content above approximately 1,000 Hz. In other words, it only works on low-frequency noise, such as that from an internal combustion engine noise. Therefore, wind noise most likely exists above 1,000 Hz, and not a candidate for treating with ANC.
3. The technology works well for low-frequency pure tones, such as that generated by fans rotating in air (blade-passage frequency) and reciprocating ICEs with distinct tonal content, as the ANC system can automatically adjust to variable tones in real-time, sample it, and immediately cancel tones with equal and opposite sound waves (180 degree out of phase). None of this applies to an electric car - no low-frequency pure tones would exist in an electric car, in my opinion.
I know Honda/Acura, and a few other automotive manufacturers, are using ANC, but their ads are misleading, as it isn't really sampling interior cabin noise, but sampling it at the engine, where a 2-D place wave exists. You see inside a car cabin, sound waves spread in a 3-D pattern, which cannot be cancelled, irrespective of what you may hear or read from these auto manufacturers.
Now ANC headphones are a different story, as the volume of space under the earmuff cup is small enough to simulate or create 2-D sound wave propagation.
Now that you are impressed, the bottom line is ANC technology will not work effectively on tire or wind noise audible inside the cabin, mostly due to the 3-D issue I mentioned above. Here the manufacturer (Tesla) is relying upon, and correctly, an air-tight cabin and solid floor and firewall materials; all designed to block and attenuate the penetration of noise. That's it in a nutshell.
