That is one of the reasons that power companies sometimes give for not approving larger grid connected solar systems. Before they would let our 27kW system go live they had to test the grid voltage and ensure that it wouldn't go over the maximum voltage.
As I understand it they set the voltage at the 11kv to 415v pole mounted or padmount transformer to ensure that the person furthest from the transformer receives at least the minimum voltage they are required to supply. This all works fine with the electricity flowing from the power station, through the grid and out to the customer. However, when solar systems start popping up along a street there is now power being injected at mutiple points. This can raise the grid voltage locally. It is not a reason to block solar, it's just the grid needs to adapt from it's traditional one way flow of energy.
