NerdUno
Other than offending the Tesla worshippers, what was it about the Forbes article that was inaccurate?
Tesla appears to put overenthusiastic Supercharger users into slow charge hell “permanently.”
That's the starting rate for 60s. It's only the bigger batteries that get 110-115kW, and then it's only if they're nearly empty.Just my .02 here; in 8 months of ownership of a 60s and trips from San Diego to Santa Fe and San Diego to Atlanta and back, along with a few uses of the San Diego supercharger, I have never seen (what I consider to be) the mythical 3 digit rate of supercharging. To Atlanta and back, stopping so supercharge 30-40 times, I have seen charging consistently starting at 90-95kW and tapering from there. The San Diego SC rates are all over the map, high 30s to low 80s.
And since I charge to 100% daily (which is between 231-238),
Why don't you use AC? Exclusively DC? No plug where you live?
A 60/75 kWh pack has less modules in it, so less cells to receive power in parallel, therefore it can't take as much power overall.Reasoning???
Oh and BTW there is no "reserve". My car did shut down right when I hit 0 miles so it does seem that the range displayed is accurate and there isn't any phantom "10 miles buffer" that some people claim or falsely believe.
I remember Nissan said that with my Leaf. They even said charging via the 110 all the time wasn't good too. But who knows.Why do you ask? Tesla has never said DC charging hurts the car, or should be limited in any way, have they?
Theyve said max charging can shorten battery life. From the battery's perspective it's ALWAYS DC regardless ofhow the power starts. One way just bypasses the ac/dc converter.Why do you ask? Tesla has never said DC charging hurts the car, or should be limited in any way, have they?
Wow, my 2013 P85 "B" pack has a 232 range for my 90% at 50k miles; you certainly have lost quite a bit of range on your battery. Have you ever had Tesla check it for a bad module?
The 5 minute number also assumes an unpaired stall is available, that the SOC is very low, and that the owner is charging to 90%. The first item can be hit or miss. The second item is a reasonable expectation for most stops. The last item is likely not the case.How does 5 minutes more per supercharging session add up to 30 minutes more on a short trip? I wouldn't call a trip needing 6 supercharger stops a short trip. that's more than 700 miles of driving. Is 30 minutes difference really noticeable on a trip of more than 700 miles, when you're probably eating lunch or dinner at some of those stops anyway?
Yes, absolutely. I don't charge to 100% because Tesla is honest about that, as you say. But never have they said repeated use of fast-charging DC chargers hurts the batteries. If the OP is getting real info (I hope to goodness he's getting a tall tale from somebody in Tesla service to cover a defective battery they don't want to fix, and that's my strong suspicion), then we've all got to look at how we care for our cars differently.Theyve said max charging can shorten battery life. From the battery's perspective it's ALWAYS DC regardless ofhow the power starts. One way just bypasses the ac/dc converter.
I think the reasonable theoretical number for SC hopping with a 90D in relatively dense locations is closer to 3 minutes - assuming charging from a 15% SOC to a 65% SOC. However, I recognize that Supercharger density varies greatly depending on location, and that driver style also varies. A funny thing about doing this math, though, is that one is unlikely to underperform relative to theory. Underperforming means the Supercharger is, for some reason, not supplying the appropriate charge. That issue actually works in favor of the owner, because it means their cap is no longer artificial. Instead, it creates parity and removes the theoretical penalty. The only way that the capped owner would be harmed is if the Supercharger was outperforming for other vehicles - for some reason no longer tapering, or providing 150kW, etc. Or, of course, something else I'm missing.
Translating that, and this would assume no tapering (so being conservative in your favor):2016 SoC Arrival 27%, 62% Departure. Total charge time 21m (+35% SoC)
2017 Soc Arrival 23%, 63% Departure. Total charge time 28m (+40% SoC)
I am not saying it is progressive, just that it appears to be so, but with my limited dataset, I can't really make a claim one way or another.
I will say, though, that even at 5m (and that estimate seems to be low from my experience so far) that still adds 30m to an otherwise short trip... To put it another way, it adds up to 5% more time than before. This is on top of the additional charging time penalty that already existed. So a trip that takes 9 hours in an ICE now takes 12.
I find this thread interesting, because the OP says he only has 30k miles and has encountered this "throttling". I have 148k miles. My daily commute I cannot make it to work and back on a single charge. I range charge to 100% every morning I go to work (I have to, or else I wont have enough left to make it to the supercharger in order to get home), and I supercharge almost every day during the week, sometimes twice a day. Twice a week it can even be 3x daily. I've been doing this for 4 years now. The number of times I supercharge is ridiculous, probably more than anyone else ever has. There's no way the OP has even come close to the number of times that I supercharge. Yet I have experienced no throttling and always observe around 117-118kWh during the beginning of charging. It does take about 30-40 minutes to go from 0-80% and from 80-100% can be another 30-40 minutes. This is normal AFAIK.
