No think it is in the UK too where I am as others on Facebook have itI wonder if it is only available in the US at this point. (Does that change require regulatory approval?)
Ok, the NotATesla app says US only:No think it is in the UK too where I am as others on Facebook have it
Same page it says available in the UK and others here have it. Just triple checked with them.Ok, the NotATesla app says US only:
It also says only certain model years for the Model 3.
100% of devices are capable of encryption. They already use it over internal LAN.It's worth remembering that you can't just turn on encryption on the bus - everything attached to the bus needs to be able to process it.
The main computer can easily add encryption, but not so much the window motor controller, for example. Many small items on the bus are not made with microprocessors that can handle encryption, assuming they're capable of being reprogrammed over the CAN bus, in the first place.
Adding encryption would likely be a rip-and-replace activity.
But, like the previous posts said, the stbus that matters isn't easily accessible without ripping open the dash. The easy-access bus in the shouldn't access critical stuff.
That's not how encryption works.And.. the best part... you break all diagnostics and the ability to monitor anything unless you have the magic key :/ Which poses a problem when you have a few million cars. Its virtually impossible to have a unique key for each car and managing even a few keys can be problematic. So you are left with a common key which renders the entire thing moot.
We already talked about this. The ethernet has the advantage of having 100MB/s bandwidth vs 1Mb/s. I was wrong in that standard CAN is 8 bytes max for the data field in a frame. In addition, not all traffic is encrypted over the internal ethernet; this may be by limitations in existing hardware as encryption was rolled out in 2019 IIRC, though I haven't found a write up explaining which devices are putting out unencrypted traffic.100% of devices are capable of encryption. They already use it over internal LAN.
Which module? ghost? boost? bonus?Anyone try installing 2022.24.5 with the ingenext module?
I assume the safe updates applies to all of them, but I'm using the ghost + Nice Try.Which module? ghost? boost? bonus?
The idea that they have not enough power to encrypt 100x smaller traffic is just wrong. They have enough.We already talked about this. The ethernet has the advantage of having 100MB/s bandwidth vs 1Mb/s. I was wrong in that standard CAN is 8 bytes max for the data field in a frame. In addition, not all traffic is encrypted over the internal ethernet; this may be by limitations in existing hardware as encryption was rolled out in 2019 IIRC, though I haven't found a write up explaining which devices are putting out unencrypted traffic.
It's more naïve to assume all devices are capable of encryption than not. There may be limitations in architecture and compute that make it impossible for encryption to be deployed, let alone done fast enough for RT communication. Differences of milliseconds will drastically affect the entire performance of the car and would require rewriting much more than the communication layer.
Are you really so sure about that? With data being sent of wheel speed/position, suspension position sensors, accelerometers along body locations, and the rest of the sensor suite on the CAN bus, it seems fairly likely there are critical RT operations being performed by the modules. The brake position and steering wheel position, for example, are both being updated via CAN for the ABS and traction control system respectively.The idea that they have not enough power to encrypt 100x smaller traffic is just wrong. They have enough.
There are countless super lightweight algorithms of symmetric encryption, considering that they all can exchange the key over signed and encrypted LAN.
CAN bus is not realtime by any means and processor time for encryption is nothing compared to the time devices standing in slow queues, waiting for their turn to send the message.
I have both power frunk and trunk from evoffer. No issues at all with my boost sr. I also have a 9” Linux display and seat massager which work without issue.Anyone here installed electric trunk or frunk from evoffer (aka Tesla offer) or hasshow? Any issue or interference with the ingenext module especially since they said evoffer’s also tap into the canbus.
It's a multiplex serial bus. It's not realtime by design. And it can't function without the queue. I don't need wiki references, I worked enough with it. Encryption delay is negligible and to make all those hacks permanently fail you don't even need to encrypt everything. So it's just a matter of attention.Are you really so sure about that? With data being sent of wheel speed/position, suspension position sensors, accelerometers along body locations, and the rest of the sensor suite on the CAN bus, it seems fairly likely there are critical RT operations being performed by the modules. The brake position and steering wheel position, for example, are both being updated via CAN for the ABS and traction control system respectively.
Either way, modules aren't taking turns and any lower priority messages simply get dropped. There isn't any queue for high-priority modules.
It's realtime by convenience; every controller operates with it and performs critical operations over the bus. You also keep saying queue as if that is a thing within the spec. It's timing based on priority and arbitration with transmission delay. If a lower priority node sees a transmission it just waits until the next. Any small disruption to the order can compound to a lot of missed frames and disruption over the network for lower-priority nodes.It's a multiplex serial bus. It's not realtime by design. And it can't function without the queue. I don't need wiki references, I worked enough with it. Encryption delay is negligible and to make all those hacks permanently fail you don't even need to encrypt everything. So it's just a matter of attention.
Thanks. Glad to hear they both work. Planning to do the same!I have both power frunk and trunk from evoffer. No issues at all with my boost sr. I also have a 9” Linux display and seat massager which work without issue.
