@jlz78 - your last few posts suggest that since Tuesday you have switched to Intelligent Octopus to use with an existing Zappi (presumably mentioning a different charger when applying).
If so it's possible that delays & charging issues are related to the fact that Octopus do not yet consider it compatible & you may continue getting unexpected results. Surely if it was as simple as using it as a dumb charger then all brands would be compatible? Maybe the 'Intelligent' Octopus bit handshakes with the 'smart' bit in certain chargers but not yet for Myenergi? However if it is possible to forward view the slots Octopus would offer, switch to 'dumb' then manually set those slots in the Zappi this would indeed get around things. Can that happen?
Either way, as another Zappi user I'm interested to follow progress (but academic for now because I expect Octopus will increase the rates soon & in a couple of weeks we add another EV. I tried the Intelligent Octopus configurator but it wouldn't accept either that or the Zappi, just the Tesla & Type 2 meter but I need to reliably charge both cars via the charger so have to stay with Go Faster for now).
