While I expect their upgraded tire inflation system to be better than current systems the fact is they already exist on tractor and trailer. The current systems are able to detect leaks and keep the tires inflated without sensors. This is because a semi always keeps air pressure in tanks for friction braking around 120psi. Semi tires are inflated to roughly 95 (application dependent) with a one way valve keeping pressure from those air brake tanks flowing to the tires at all times. We have had them on the majority of our trailers for the past 5 years.
The Semi doesn't need fancy extras to be a game changer. The cuts to maintenance and fuel are more than sufficient on their own especially in slip seat operations where getting equipment into the shop for preventative maintenance is near impossible because the trucks never stop.
Interesting, if I might pick your brain.
How does the tractor know the tires are being inflated? Wouldn't there still be a problem at a road side safety check, or any situation where the tire is leaking and the engine is of (or tractor disconnected)? How does the tire pressure get adjusted downward based on ambient temp and/ or altitude? What if the valve sticks?
