I turned on manual heat today and cranked to HI and level 10. To my surprise cold air. If I switch to auto it goes hot. I switch back and I noticed below level 9 it starts blowing hot again. Anyone else seeing this?? 2018.50
If the car is drawing cold outside air, the heating element may not be able to keep up with the fan operating at high speed. Essentially the air movement is drawing all of the heat from the element and lowering its temperature. The same amount of energy is being put out by the heater, but to a much larger volume of air, which makes the air feel cooler.
I don’t think this is a hardware limitation. Seems to have preformed fine before in similar temperatures. My guess is that they tweaked with the software to make it more efficient or something.If the car is drawing cold outside air, the heating element may not be able to keep up with the fan operating at high speed. Essentially the air movement is drawing all of the heat from the element and lowering its temperature. The same amount of energy is being put out by the heater, but to a much larger volume of air, which makes the air feel cooler.
Any M3 owners able to confirm that they get heat on blower settings higher then 8? Looks to be a growing list of those that don't... I'm wondering if this bug impacts all current drivers. How does one report or escalate a bug. Would sure be nice with -20C weather coming this week in Chicago to have hot blowing air.
Ironically this capability works when in park with romance mode. I literally use romance mode now if I get in the car and want to warm up my hands a bit...
