19" rimsCanada's Tesla website dropped the LR from 568KM to 538KM. Anyone have any idea why?
I havent seen that P/N before, but then this wouldnt worry me too much.Any idea what battery this is?
Part number 1660112-00-B
Then this is a good confirmation for your battery pack. 3L = Panasonic 82kWh.My CoC document states I have a E3LD, v19 with 567km range.
That is were they all are when delivered to the customer. This is around 79,5kWh and usually moves up into the low 80's initially.The most I've seen was 311 miles at 100% rated on the app (slider to right).
What's your daily charging limit? 80% / 90%?Only actually charged to 100% once
That is low indeed...around 76,6kWh. But then this does not mean, that your battery pack is bad. The Panasonic 2170L BMS is actually quite picky.got 300 miles rated range
So this means that Tesla is manufacturing 82kWh Panasonic packs in China? (This pack is made in China.)Then this is a good confirmation for your battery pack. 3L = Panasonic 82kWh.
^ This is what got my attention as well... that it's not Made in USA - but I've not found any other 2021 M3 Performance stickers to compare against. I was concerned that the CoC document + BMS config had the wrong battery type on it, especially with parts shortages, and it's actually a slightly smaller battery installed. Would be great to see if others have the same P/N.So this means that Tesla is manufacturing 82kWh Panasonic packs in China? (This pack is made in China.)
I did not realize that - thought it was mostly other vendors, LG, CATL, whatever, at this point. But I don’t pay close attention I guess.
As I mentioned in a PM, this is normal, for low SOC. This is just a projection and is highly dependent on rounding error. It’s not uncommon to see variation of over 20 miles in the estimate if you’re at a low SOC. You saw a variation of 6 miles at 20% - one picture was not projected to 100%. It’s just the math. 20% could be anywhere from 19.5% to 20.5%.it fluctuated a LOT, 3) it's a month old with 1100 miles. See screen grabs attached, taken one after the other.
Thanks, sorry I forgot you mentioned that. Makes sense!As I mentioned in a PM, this is normal, for low SOC. This is just a projection and is highly dependent on rounding error. It’s not uncommon to see variation of over 20 miles in the estimate if you’re at a low SOC. You saw a variation of 6 miles at 20% - one picture was not projected to 100%. It’s just the math. 20% could be anywhere from 19.5% to 20.5%.
At 5% I would expect it to predict between 290 miles of range and 350 miles of range, for example. While at 95% you might see a range of perhaps 3-5 miles on the estimates.
The numbers 340/352 makes perfect sence for the LG E5L battery( slightly over 79kWh) so it is highly probable that this is the reason.Same for others country in Europe. It could be LG E5L pack instead of Panasonic E3L.
More information here :
The Pana 2170L is US made and was imported for the M3P as I understand it.So this means that Tesla is manufacturing 82kWh Panasonic packs in China? (This pack is made in China.)
didn't certification showed 4,6 h old LG, 4,8Ah old Panasonic, and 5.0 for both new cells? If so difference between new LG and Panasonic should be less than 0,1Ah or 2%The Pana 2170L is US made and was imported for the M3P as I understand it.
I think I did read Teslas word for it, about starting to use locally made batteries instead of transporting batteries over the world.
How can you say it’s China made? Serial no?
There most probable will be a LG ”82” pack with the code 5L( or E5L, E5LD for the whole code). It doesnt really reach 82kWh according to both the LG M50-cell spec, and the EU CoC’s etc that eivissa have shown. Its very likely to be 791-79.2kWh.
The LG M50 cell(if its the regular one used), is marked/specified 18.2Wh and tested to reach about 18.1or so which makes some 79.5kWh for the pack.
I think eivissa said ”we are expecting that E5L in the next official certification paper”.
That LG E5L shouldnt be on the streets in EU yet if I get it wright.
That certification showed which cell was used. For Panna 2170, its marked size is 4.8Ah and for the 2170L its 5Ah according to the papers.didn't certification showed 4,6 h old LG, 4,8Ah old Panasonic, and 5.0 for both new cells? If so difference between new LG and Panasonic should be less than 0,1Ah or 2%
I was referring to this post:That certification showed which cell was used. For Panna 2170, its marked size is 4.8Ah and for the 2170L its 5Ah according to the papers.
In real life, a cell marked 5Ah doesnt always reach 5.000Ah. Thats one of the things battery test nerds check.
Also, we are talking Energy( Wh or kWh) and the Energy in a batteri is Ah times average voltage during tha discharge(marked as nominal voltage on the cell). This differs, specially if you change the chemistry like it certainly lookin this case. Tesla Panasonic classic is NCA, LG M50 is NMC.
5Ah can be both 17Wh and 18Wh due to this.
Panna ”old” 2170 is marked 4.8Ah( gives 77.8kWh on the pack level).
LG M48 is also marked 4.8Ah but only reach 75kWh on the pack level.
Nerd level explanaition —> Its also marked 17Wh, which explain the difference.
17Wh/4.8Ah= 3.54 volt on average.
The panasonic 2170 thats probably the one used in M3 says 17.8Wh= 3.71v in average.
We know that the EU LR with E5 LG M48 cell has about 75kWh, and we know it has a WLTP of 580km. The E5L is supposed to get 614km, which for the same consumption ad up to 79.4 or so.
For the M3P the difference between 567km and 547km ad up exactly with the change to a battery with 79.2kWh capacity.
I do not follow in the reasoning (but its maybe me…)I was referring to this post:
It looks from certification and states cells capacity, there is zero reason to misrepresent them. I think these new cells have few similarities with same name cells which were available for years. NMC have the same or better voltage...MASTER THREAD: 2021 Model 3 - Charge data, battery discussion etc
I wonder why the Europe/UK LG/capped Panasonic never showed even 353 miles (the advertised epa at the time) then? Not sure what’s changed so that they are advertising 360 miles with a 75kwh battery? Although advertised and what ends up being displayed on the screen are two different things I...teslamotorsclub.com
If you charge it to 60% maximum daily and never or barely ever use DC chargers it does this...
If you charge it to 80%/90% and use any kind of DC chargers (20KW or 250KW, it doesnt matter), then it does this...
2) it fluctuated a LOT
Simply ENVY.After the 2021.32.21 I had a NFP drop the same night(from being stable at 80.3-80.4 for quite some time). This, despite a regular sleep at 25-35% and charge to 55-56%. The drop was about 0.5kWh, and after a few days sway it was stable at 79.9. Then it was stable for about one month, during this time I got 2021.36.5 which didnt show any direct change.
But shortly after I charged to 100% for a trip and then the NFP started to rise. Was up to 80.3 for a few days, today I charged to 100% for a trip to Tesla SC. The NFP increased to 80.4 (reached 80.8 nominal remaining).
I had a few higher charges last week so the BMS shouldnt be that badly calibrated.
It seems like there is a different NFP-calc from the BMS, or maybe its only a coincidence? The behaviour is not the same, more or less the
opposite from what I have seen before( the same as you eivissa).
