OK, I've got maybe 100 miles under my belt now on FSD Beta. Here's my impressions. The good and then the bad.
Freeway driving is WAY, WAY, WAY better.... {respectfully shortened for brevity...}
Good write-up and pretty similar reaction today in my limited first day (2 different trips of about 15 miles each) on several of your points.
Just a couple of additional observations:
- Very timid entering and navigating turning circles. I needed to goose it a bit most times if there were people behind me.
- Left turns will take a bit to get used to as the car tends to drive straight for a bit longer than a human before making what then becomes a sharper left turn. At 'T' intersections I initially felt like the car would drive straight across and off the road, which was a false concern.
- Similar to AP, it still approaches stops and hard brakes at the end (my sensitivity is extra high now after trying to do most braking on low regen for the past 2 weeks)
- It is usually a bit too timid in intersections (i.e. not going quickly when it is clear, but then deciding to creep out as the oncoming cars are finally nearing). However, about 20% of the time it decides to be very aggressive (i.e. timing a left turn perfectly between multiple oncoming cars without slowing hardly at all).
- Navigating out of a complicated grocery store parking lot was nothing short of amazing as it figured out its complicated route with lots of surrounding action in real-time.
My suggestion to new FSD drivers:
- Start off simple until you have a feel for its boundaries. There is no need to try construction zones in a downtown area during rush hour at this point if you are not even sure what it will do in simpler scenarios 80% of the time.
- Set your speed to +0 if it is not already set there. As mentioned before there are times it can decide to accelerate PDQ and +5 mph over can make a big difference in safety margin.
- Think twice before getting the FSD Beta unless you are totally in the mindset of helping Tesla improve a feature still under development. Anything else will only lead to frustration and disappointment due to wrong expectations. Additionally, unless you are simply demoing for a friend, I think it's safe to say 90% of all FSD engagements will be with a solo driver. I doubt most spouses will accept riding shotgun in FSD mode. I think this would feel more like an E-Ticket ride for all but the most seasoned passengers at this point.
- Never, ever let your guard down. It is totally amazing, but it can at times take a completely unexpected action. Complacency and false trust is what is going to bite people in the end.
You will always be in control and safe unless you let the car put in you an unsafe situation. After day 1, I can say I am very, very impressed with what I see so far, but it also still has a long, long way to go. Exciting times indeed...
