I think the part that is a little different & more significant (which you may have missed when looking at that video) is now he is saying/speculating that both of the motors will have the carbon sleeved rotors (in other words, both motors will be “plaid” motors).
Right, which is why the docs we have seen so far show a 3D3/ 3D7 motor combo for the AWD car, but a 3D3 / 5D1 motor combo in the performance model, and the 3D3 is already a motor they make - it's the one in the front of a Model 3 AWD or M3P today.
And of course why the docs only mention a "Base motor (600A rear)" or "Performance Motor (800A rear)". Because clearly the front motor also changed, it's just not mentioned.
And of course why the docs list the same battery for all the cars.
Speculation is fun, but it gets silly when we have the docs down to part numbers.
Oh, and let's not forget that 80 HP number. So the whole car has 40 more HP per axle? They built a whole new motor for that and that's all they could get out of the Plaid motors, despite them being 200HP more than M3P rear drive units already?
More HP in the front axle is in the wrong place. If you've got battery power to spare, you want it on the rear axle, and a single Plaid motor is already 350kW / 480HP. Why would they up the front axle power when it can already do 184HP and we're only claiming ~600 HP total? It makes no sense.
Here's my "speculation" - 1200A, 350V battery. 1100A usable. That's 385kW vs the 340kW we get today. That's 60HP more. This will drop 0-60 to 2.9 seconds. This will all be in the rear axle, increasing power from 202kW to ~250kW. The rear motor will be "better" and will be able to maintain a full 250kW to 100MPH+, while the front axle will fall off at the same 40 MPH we see today. This will make a much faster car 0-100 MPH, and the only change they needed to make was a single motor while maintaining the same battery, front drive unit, and the rear inverter (Plaid inverters are already M3 rear DU inverters).
You know, exactly like the original M3P did, and all the docs we have seen so far indicate.
