Olle
Higher pack voltage has been mentioned time and time again as a solution to high speed acceleration in this thread. It is true that back EMF increases with speed and that higher pack voltage could overcome this. As @gearcruncher and others have repeatedly mentioned, different packs may not be in the cards due to the cost. The new S/X is a good example. Same pack for all versions. One of many drawbacks with just raising the voltage is that regen becomes less efficient.Agree. 0-50mph is already fast enough. What we need is better 50-80. Higher pack voltage would go a long ways at solving this.
I think that if more voltage pack voltage to overcome back EMF is what they need, it's much cheaper to lower the motor voltage by changing the stator winding in the rear motor. Tesla is already using different windings in the carbon sleeve motors, one for the 900V version in the trucks and another for the Plaid.
In this scenario the front motor can remain as is and fill in some of the regen gaps where a re wound low voltage rear motor is less efficient. The rear motor, being a reluctance PM machine, actually has two efficiency bands, one at lower speeds where the load angle causes the torque to rely on stator field and the rotor's permanent magnets and another one at high speed where the stator field cancels the PM field and where the torque instead relies mostly on the rotor's reluctance field.
