davidc18
I am expecting that there is no HUD and the 15 inch screen is it. I don't see any issues with this setup.
I think his gist is your previous vehicle had physical instruments and pretty much physical instruments are the only type which would not need a "reboot" and a failure of a single dial would not necessarily mean a total failure of the whole cluster.
I thought the Fiat and Mini Cooper did, but I just checked and both cars have dedicated driver gauges for speed, fuel level, etc.
As far as the speedo goes, I only use that to prevent getting a speeding ticket. As a teen I drove for months without a working speedometer. However, I would not feel comfortable if the only screen providing information went blank.If there are any bugs or performance issues on that screen, people will lose confidence when driving the Model 3. I would feel very wary if I ever saw my speedometer lag out. It's unsettling to even think about now.
I think it depends on which type. There are ones where the only thing showing is pretty much the speedometer (and other basic stuff like tachometer/odometer, fuel gauge etc), so the likelihood of that freezing and rebooting is unlikely (given simplicity).I have owned other vehicles with full digital screen speedometers/instrument clusters and never had to reboot those, so I think making a rock solid instrument cluster is not a high bar even when not using physical gauges. Tesla owners are used to the quirks, but it is true a IC lockup and reboot might be concerning to the typical car buyer coming from other makes.
This tends to making parking lots and driveways difficult.Tesla never goes backwards, only forwards.
I provided my personal experience and estimated number of driver display and center display reboots in over 3 years of ownership. Should Tesla continue to work on reducing the incidence of spontaneous display reboots? Of course, and I'm sure that is ongoing. Are spontaneous display reboots dangerous? I don't think so.18 seconds until the reboot can begin and then 12 seconds to reboot. Again, like the previous owner mentioned, not the end of the world. But this is something that should be reliable and shouldn't be ever freezing/resetting.
Thankfully, Elon Musk doesn't think like that. At 19:30.
>So I think that’s an important thing to do, and then also to really pay attention to negative feedback, and solicit it, particularly from friends. This may sound like simple advice, but hardly anyone does that, and it’s incredibly helpful.
Asking for speedometers to work as reliably they have the past 15 years...is not a high bar. Nobody said they should move to physical instruments. Who said that? Who are you replying to? Where is it shown that physical instruments are more reliable than digital instruments? Where are you getting these points from? I'd like some sources.
All I have said is that, to increase mass market consumer confidence, the speedometer (and Autopilot information, etc.) would be best on a dedicated as-close-as-failsafe-as-possible viewing area. There's no issue with digital screens and, out of personal preference, I'd not want any physical instruments in the Model 3.
See arnis' mock-up image above--in my mind, that gives a stronger feeling of comfort and reliability and confidence.
See this video:
Nobody's claiming a single screen is going to significantly hurt the Model 3's reception, but I think it's a key point to be wary of when the Model 3 launches: are there further reliabilities in the screen/UI/OS to avoid these mishaps? What failsafe measures have been implemented?
OK, right: that's 5 losses of the speedometer over 55k miles. My current car, far cheaper than a Model 3, has over 70k miles and I've never lost my speedometer. Ever.
Absolutely. It's a loss of safety in my mind, though: I can't see what Autopilot is sensing, I can't see any errors (tire pressure, airbags, battery errors), I don't know if my turn signals are operating (maybe the clicks are enough?), etc.
How many losses of these functions are acceptable in a car? What's the limit? Maybe we have different limits.
But ones where it integrates other applications (including nav) and have the entire cluster as digital (basically the cluster is a full computer)
First result on google shows a thread about a Volt cluster failure and suggestions to do a reboot procedure. It's not that uncommon as there seems to be plenty of similar threads at the GM-Volt forums (some of which require a full cluster replacement because the cluster kept blanking out).Mine was this type in a Chevy Volt. Never had it freeze or reboot on me in 45k miles. I dont even know if there is a user initiated reboot procedure for the Volt. Maybe I was just lucky.
Not sure that a good way to keep costs down would include crazy rare ultra-wide LCD ratios they have to custom order. Also doesn't make sense to me that they'd take out a relatively cheap part at this time due to the economies of scale (the driver screens they use in Models S/X already) just to replace it with
Agree HUD is most likely... just wanted to throw out a possible solution (no matter how unlikely) that would please both the anti-HUD and anti-center screen crowds.Not sure that a good way to keep costs down would include crazy rare ultra-wide LCD ratios they have to custom order. Also doesn't make sense to me that they'd take out a relatively cheap part at this time due to the economies of scale (the driver screens they use in Models S/X already) just to replace it with
....nothing. Nvidia presentations show ability to push graphics to three 4K 60fps displays, so I think the "single computer" argument I've seen elsewhere is also silly. Also, Model 3 is most likely not going to be level 4 enabled at launch and one of the main "safety features" Tesla implemented with AP is the screen flashing/nagging messages right in you peripheral vision, which you lose with a screen off to the side. Not saying there's definitely a HUD, but I'd say it's likely.
With modern seat belts and airbags I see no safety concerns with the Model 3 center display design as shown in the prototypes last year.
That is not to say that the production version of the 3 could have a different center display design. It very well might. We don't know.
Silicon valley, Autopilot-forefront, brand building Tesla: Why on earth would they ditch that simple but beautiful, highly recognizable AUTOPILOT DISPLAY that all S and X have in their IC?
It shows your lane, your car ahead, your speed limit, whether or not you're TACCin', Auto-Steer'in or approachin' a road barrier
I believe in HUD
There's a couple things that changed that make it mor
e likely the Model 3 will keep a floating screen:
The S/X screens are pretty similar (same 17 inch, portrait orientation). Model 3 will use a 15 inch landscape orientation and does not need to consider sharing a similar design to older screens (given totally different platform).
The Model 3 dash and front seat position is pushed forward in the car in order to maximize legroom. If you look at the design of the screen, it is away from the dash and toward the driver, such that the entire screen is floating. This is different from the Model X alpha, where it is pretty much on the same plane as the dash (only the top half is floating, bottom is already flush).
What It's Like to Ride in a Tesla Model 3
The positioning of the screen closer to driver serves two purposes: account for a further forward dash position and to have the speedometer larger and more visible in the field of view (given there is only one screen).
So to make the Model 3 screen flush, if they keep in same position, they either have to add a surround or move entire dash forward (which would seem to be more expensive). Or they have to push it toward the dash away from driver (which may cost less, but compromises the design decision made above).
