I'm under the impression that deep discharges will do nothing. 90% charge or more, leaving the car for a day or two, will help balancing cells if they are unbalanced. Otherwise it's just an estimate number, don't fret it. The important thing is how many kWh you can store in that battery. Alternatively driving from full to empty will tell you what range you really have, if it's that important to know.
Dang, down 18%. Have you had Tesla look at it?It seems there are nobody have a worse battery degradation than me, at least from users using Teslafi.
My M3 long range AWD OCT 2019, range at 100% down to 255.3 from 310 with only 11K miles on it.
100% charge to 5% x3 times, quickest to try this at a Supercharger. If this doesn’t reset your battery then for sure you need to set up a service call. At this rate you will be getting a new battery under warranty.It seems there are nobody have a worse battery degradation than me, at least from users using Teslafi.
My LR RWD last charged to 324 miles at 99% back in the summer of 2019. I did notice a projected range decrease beginning with one of the fall updates and it's gotten lower ever since.
Now it estimates 285 miles at 100% in the app. I've only charged it over 90% less than a handful of times ever. I drive about 60-80 miles a day and usually charge to 80% daily.
I'm not worried though and I may charge to close to 100% and let the cells balance to see if there's any change.
So how deep did you discharge before you started getting the estimated 100% to start creeping back up? I'm trying to get a better idea of how deep I need to discharge if I do decide to try and get my 100% range back up again someday.I experienced a similar drop in reported range in my 2018 LR RWD, and my commute and charging habits are similar to yours. The drop didn’t happen until after I had HW 3.0 installed in January, though, so when I reported it to the service center, they told me to increase my depth of discharge. So I started charging every 3rd day, and lo and behold, my estimated range at 100% did go back up. Not to the full ~325 miles I used to see, but 312-315 miles, so I think maybe there is something about charging habits that affect the estimate.
Anyway, I’ve gone back to daily charging, because I have solar and powerwalls, and the Q3 day charging is way less efficient. I’m just going to ignore the reported range from now on.
I’d let it drop to around 30-40%.So how deep did you discharge before you started getting the estimated 100% to start creeping back up? I'm trying to get a better idea of how deep I need to discharge if I do decide to try and get my 100% range back up again someday.
Yeah, I started experiencing the same "degredation". Turns our the car had issues estimating the correct rated range being charged to 50% everyday since I've been WFH for the past few months.
Started doing deeper cycles, and only charging once the car hits 25% back up to 90%.
Rated range is slowly improving.
I’m tempted to try this, but the way I’m driving nowadays, it will probably take me 2 or 3 weeks to run the battery from 90% to 40%. When I used to commute before the pandemic, it would have only taken 2 or 3 days.The suggestion was that you should set the charge to 90%, and then not charge again until you're below 40%. Even if that's several days later. And an added suggestion was to wait an hour or more after the last drive before starting to charge - this lets the battery cells level somewhat.
I was thinking about it, but not quite sure if this is urgent enough for us, especially during the COVID thing. By the way, the nearest Tesla service is 1 hr away.Um... you’ve made a service appt with Tesla about this right? Have you done any of the rebalancing tips/trick stuff? Hot damn!
We usually never use the battery lower than 20%, probably only got down once under 10%. I just did one SuperCharge session while intentionally bring down the battery to 10%, but not seeing any change of the trend.100% charge to 5% x3 times, quickest to try this at a Supercharger. If this doesn’t reset your battery then for sure you need to set up a service call. At this rate you will be getting a new battery under warranty.
Fred
We usually charge to 70% by the morning when my wife start her 40miles(one way) commute. When she came back, it usually about 30%. Well, this is before the COVID and we are WFH for the past months and we typically only have one long trip per week, charge up to 80% some times 90% depends on where we going.What % do you keep you car battery charged to?
How often do you supercharge ?
