Kind of a strange one here... curious if our electrician friends have any insight.
We had some crazy high winds the other night where I live, and that sometimes leads to power outages. In this case, however, there appeared to a sizable power surge. The kind that makes a power strip go POP (sounded like a big light bulb exploding). The power went out for a few seconds, then cycled back on... then off again. Then back on, and stayed on. Whole event lasted about a minute.
BUT... lots of breakers tripped. I went about resetting stuff, but some things seemed fried. Specifically, the power to my thermostat on my main forced HVAC unit... off. Possibly the transformed got fried? Guy coming out in a couple of days to check on that one... same deal for a ductless HVAC unit... no power.
The big one, though, was the HPWC. That one is on a subpanel. The breaker to the subpanel tripped. And a bunch of breakers on the subpanel itself tripped, including the dedicated breaker for the HPWC. I was able to reset all of them but that breaker, which would not return to the ON position (yeah, I moved it to OFF first).
In the morning, when I took a better look at it, I saw that the plastic cover of the HPWC was actually pushed off of the unit in the top corner... and you could see char marks. Basically, it was fried... and did so with enough force that the cover was actually blown out a bit.
The electricians are installing a replacement right now. The breaker for the HPWC is officially toast. Their working theory is... big spike in voltage goes through the breaker, hits the HPWC, there's a short in there, and it feeds power back into the breaker and fries it?
I'm an electricity idiot, so I'm probably using a bunch of incorrect terms and ideas. We're obviously replacing the unit and breaker, so we should be back up and running soon... but curious... what exactly happened here? And is there any way to protect against such an occurrence again?
