Norbert
TSLA will win
"Powers off" how much though? I assume there an equivalent to the ACC position on an ignition, say so you can sit in the car and play with the touchscreen/radio without the drivetrain contactors engaged.
You should get that by shifting into park. It doesn't shut down power as long as the fob stays in the car. Except when the "vehicle system times out." Not sure what this means. And I'd hope there is an override, for example if you are charging, and sitting in the passenger seat or back seat (with a laptop, or reading), so you don't have the steering wheel in the way, and want ventilation or heating or music not to time out. Or so that if you are connected to a Nema 14-50 on a campground, and want to sleep a few hours on the back bench, with heating/cooling set to a comfortable temperature. Maybe the touchscreen could even have an alarm clock function. Instead of timing out.
